Does anyone have any experience with the induction portion of this unit? Just over 3yrs old error code (EO95) all across burner windows. oven still works, voltage to unit is good, 20A 240V qiuck blow fuse on generator housing blown replaced fuse, radient burnes worked until induction control turned on,fuse blown again. diagnostic flow chart says to replace the generator housing complete ($600+ part) bad reviews all over the net unsure it's worth throwing parts at it. any help appreciated.
