My electric GE Profile self-cleaning convection oven wont heat up when turned on to bake. The oven reads 100 degrees but the bake element does not turn on. The broil element works. The bake element will not heat up.
I removed the bake element and measured 20.7 ohms across the terminals and there were no shorts to the bracket so I assume the element still works.
I removed the glass cooktop and tested both limit switches. I had continuity on both so I assume both limit switches are functioning correctly.
Interestingly enough, this is after using the oven at 550 degrees on the weekend, the hottest I have ever used the oven. The oven seemed to stop working a day or two afterwards.
I am going to give it a good cleaning now that it is pulled out and then put everything back together and see if anything has changed. In the mean time, any idea what is NOT working?!?! Thanks.
