| » Oven wont heat!!!!!!! |
A Model Number may help others help you.
This may help you find it. Model Number Locator Check that both the bake and broil elements work.
__________________
Here are the parts
Wiring information replacement parts for JENN-AIR JER8785QAN | AppliancePartsPros.com Here is a tech sheet and a service manual http://www.servicematters.com/maytag...s/16027223.pdf http://www.servicematters.com/maytag...s/16025644.pdf I would check the element first, should be aroun 20 ohms. See the manual on how to remove it. Note: I always attach something to the wires before undoing the element so they do not disappear back into the unit, clothes pins work.
__________________
Denman,
Thank you for your quick reply and information for parts. Based on what I told you what do you think is the problem? And for someone with no experience working on ovens, would I be able to fix it? Thanks again. Lucas |
| Display Modes | |
| oven wont heat | murrayj2 | Oven Repair (including Ranges and Cooktops) | 0 | 02-02-2010 05:28 PM |
| Top Oven Wont Heat | Dixie Dutchman | Oven Repair (including Ranges and Cooktops) | 1 | 04-15-2009 02:51 PM |
| Oven wont heat | arrynne | Oven Repair (including Ranges and Cooktops) | 0 | 03-24-2009 11:32 AM |
| oven wont heat up by itself | garhd | Oven Repair (including Ranges and Cooktops) | 1 | 08-09-2008 12:52 PM |
| oven wont heat | eelman | Oven Repair (including Ranges and Cooktops) | 5 | 05-31-2008 07:10 AM |
