I have a frigidaire oven model # fgfl87dcc. The door was slammed and it blew the fuse. Turned on fuse and the digital display shows faintly 666. It beeps every 30 seconds. Shows that the door is locked, but is not. The oven light stays on. Nothing works. I removed back panel and discovered that the indicator light to tell you the convection fan is on broke and was inside the space that contains the ecm and wiring. One of the electrical connections for this light was discolored compared to the other. Could it have been possible that it touched something and shorted everything out and fried the ecm?
