Our Maytag Gemini Electric Double Oven Range: We cooked in the lower range this evening. When the meal was done, we turned off the oven. We then tried to set the timer for 5 more minutes - nothing worked. Only the clock and the oven lights now work. Also the lower oven "on Indicator line is lit up , but the oven is not heating. When we try to push any other buttons, an amber "006" appears briefly.
We shut off the breaker and then turned it back on. The same problem exists. Our oven worked fine until now
