Having heating problems with oven. Oven will heat to set temp. noticed oven element continues to glow red. Oven will keep cooking at high temp burning food on top. Will adjust temp. to higher and lower and oven will not respond. Occasionally the oven will not let you select bake because key pad states function not available. Have to turn off breaker to reset key pad. Oven will give temp. as it climbs up in pre heat mode and will not adjusted temp higher or lower. Baking element has no black or burnt areas. Glows red continuously. Already replaced oven sensor. Would this be the clock W10157249 (circuit board??). Thank You!!!!
