On My Oven Listed Above The Bottom Element Is Not Working Properly. It Warms Up A Little Then Stops. All Other Functions Of The Stove Work Fine Including Top And Broiler Elements. I Have Removed And Checked The Element Itself With My Volt Meter And It Tests Ok. I Just Tried Resetting Breaker And Set The Oven To 200. Element Got Orange And The Oven Heated And Beeped, Ok. Tried It At 300 The Display Shows Its Heating But Now The Bottom Element Is Not Heating. Any Thoughts?
