Discuss
Handle falls off of oven all the time
 in
I would be grateful for any help you can provide. I do not really think that heat has anything to
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Handle falls off of oven all the time
  #1 (permalink)
Old 03-05-2014, 07:38 PM
Junior Member
jbywater is on a distinguished road
Default Handle falls off of oven all the time
Model Number: 79094332703   Brand: Kenmore   Age: 5 - 10 years
I do not really think that heat has anything to do with it
We have had this oven for quite a while now and it has been plagued with a handle that unscrews itself just from opening and closing the oven door. Anyways it has happened since almost the first use and its not much fun to have something in the oven that needs to be taken out and having the handle fall off in your hands as you try to open the door. I have adjusted to it happening and just tighten the screw with my thumb every time i open the oven, but when other people are here its kind of startling to them when the handle falls off. Although it is fun to look at them and ask "what did you do?"
is there any remedy for this? i can not believe this is a common issue, and have searched google for it multiple times.
If this is uncommon i wanted to ask about a possible fix i thought of just to see if it is possible and safe. I was wondering if i put some silicone on the screws just to hopefully give them the friction to hold it in place with the pull of the handle. However i am not sure if silicone can hold up to the heat, or could turn toxic, i am cooking food in there. I know the screw gets pretty darned hot just by trying to grab it to open the door. I also really dont know if they make a better product to increase friction between screws and nuts already. maybe something safer? graphite or something like that. or if silicone is ok is there any special kind it needs to be? or is there even a different product that is specially made for this that someone didnt apply to my oven for some reason?
Again any help would be appreciated.
Just to stop the question before it happens.. yes i have re tightened it with a screwdriver several times and not just my thumb... (thats the first question i would ask too) thanks
Related Models
Kenmore 79094332703 ELECTRIC RANGE
Kenmore 79094332704 ELECTRIC RANGE
Kenmore 79094333700 ELECTRIC RANGE
Kenmore 79094333701 ELECTRIC RANGE
Kenmore 79094333702 ELECTRIC RANGE
Kenmore 79094333703 ELECTRIC RANGE
Kenmore 79094333704 ELECTRIC RANGE
Kenmore 79094333706 ELECTRIC RANGE
Kenmore 79094333707 ELECTRIC RANGE
Kenmore 79094334700 ELECTRIC RANGE
Kenmore 79094338800 ELECTRIC RANGE
Kenmore 79094338801 ELECTRIC RANGE
Kenmore 79094338802 ELECTRIC RANGE
Kenmore 79094338803 ELECTRIC RANGE
Kenmore 79094338804 ELECTRIC RANGE
Kenmore 79094339700 ELECTRIC RANGE
Kenmore 79094339701 ELECTRIC RANGE
Kenmore 79094339702 ELECTRIC RANGE
Kenmore 79094339703 ELECTRIC RANGE
Kenmore 79094339704 ELECTRIC RANGE
Kenmore 79094342700 ELECTRIC RANGE
Kenmore 79094343700 ELECTRIC RANGE
Kenmore 79094343701 ELECTRIC RANGE
Kenmore 79094343702 ELECTRIC RANGE
Kenmore 79094344700 ELECTRIC RANGE
Kenmore 79094348800 ELECTRIC RANGE
Kenmore 79094349700 ELECTRIC RANGE
Kenmore 79094352700 ELECTRIC RANGE
Kenmore 79094352701 ELECTRIC RANGE
Kenmore 79094353700 ELECTRIC RANGE
Kenmore 79094353701 ELECTRIC RANGE
Kenmore 79094354700 ELECTRIC RANGE
Kenmore 79094354701 ELECTRIC RANGE
Kenmore 79094359700 ELECTRIC RANGE
Kenmore 79094359701 ELECTRIC RANGE
Kenmore 79094362700 SEARS/ELECTRIC RANGE
Kenmore 79094362701 SEARS/RANGE 0582
Kenmore 79094363700 ELECTRIC RANGE
Kenmore 79094363701 ELECTRIC RANGE
Kenmore 79094364700 SEARS/ELECTRIC RANGE
Kenmore 79094364701 SEARS/RANGE 0582
Kenmore 79094369700 SEARS/ELECTRIC RANGE
Kenmore 79094369701 SEARS/RANGE 0582
Kenmore 79094372700 ELECTRIC RANGE
Kenmore 79094372701 ELECTRIC RANGE
Kenmore 79094373700 ELECTRIC RANGE
Kenmore 79094373701 ELECTRIC RANGE
Kenmore 79094374700 ELECTRIC RANGE
Kenmore 79094374701 ELECTRIC RANGE
Kenmore 79094379700 ELECTRIC RANGE
Kenmore 79094379701 ELECTRIC RANGE
Kenmore 79094382700 ELECTRIC RANGE
Kenmore 79094382701 ELECTRIC RANGE
Kenmore 79094383700 ELECTRIC RANGE
Kenmore 79094383701 ELECTRIC RANGE
Kenmore 79094384700 ELECTRIC RANGE
Kenmore 79094384701 ELECTRIC RANGE
Kenmore 79094389700 ELECTRIC RANGE
Kenmore 79094389701 ELECTRIC RANGE
Kenmore 79094420300 ELECTRIC RANGE
Kenmore 79094420301 ELECTRIC RANGE
Kenmore 79094421300 ELECTRIC RANGE
Kenmore 79094421301 ELECTRIC RANGE
Kenmore 79094422300 ELECTRIC RANGE
Kenmore 79094422301 ELECTRIC RANGE
Kenmore 79094423300 ELECTRIC RANGE
Kenmore 79094423301 ELECTRIC RANGE
Kenmore 79094424300 ELECTRIC RANGE
Kenmore 79094424301 ELECTRIC RANGE
Kenmore 79094429300 ELECTRIC RANGE
Kenmore 79094429301 ELECTRIC RANGE
Kenmore 79094432700 ELECTRIC RANGE
Kenmore 79094432701 ELECTRIC RANGE
Kenmore 79094433700 ELECTRIC RANGE
Kenmore 79094434700 ELECTRIC RANGE
Kenmore 79094434701 ELECTRIC RANGE
Kenmore 79094439700 ELECTRIC RANGE
Kenmore 79094439701 ELECTRIC RANGE
Kenmore 79094442700 ELECTRIC RANGE
Kenmore 79094442701 ELECTRIC RANGE
Kenmore 79094443700 ELECTRIC RANGE
Kenmore 79094444700 ELECTRIC RANGE
Kenmore 79094444701 ELECTRIC RANGE
Kenmore 79094449700 ELECTRIC RANGE
Kenmore 79094449701 ELECTRIC RANGE
Kenmore 79094452700 ELECTRIC RANGE
Kenmore 79094452701 ELECTRIC RANGE
Kenmore 79094453700 ELECTRIC RANGE
Kenmore 79094453701 ELECTRIC RANGE
Kenmore 79094454700 ELECTRIC RANGE
Kenmore 79094454701 ELECTRIC RANGE
Kenmore 79094459700 ELECTRIC RANGE
Kenmore 79094459701 ELECTRIC RANGE
Kenmore 79094462700 ELECTRIC RANGE
Kenmore 79094462701 ELECTRIC RANGE
Kenmore 79094462702 ELECTRIC RANGE
Kenmore 79094462703 ELECTRIC RANGE
Kenmore 79094463700 ELECTRIC RANGE
Kenmore 79094463701 ELECTRIC RANGE
Kenmore 79094463702 ELECTRIC RANGE
Kenmore 79094463703 ELECTRIC RANGE
Kenmore 79094463704 ELECTRIC RANGE
Kenmore 79094463705 ELECTRIC RANGE
Kenmore 79094464700 ELECTRIC RANGE
Kenmore 79094464701 ELECTRIC RANGE
Kenmore 79094464702 ELECTRIC RANGE
Kenmore 79094464703 ELECTRIC RANGE
Kenmore 79094469700 ELECTRIC RANGE
Kenmore 79094469701 ELECTRIC RANGE
Kenmore 79094469702 ELECTRIC RANGE
Kenmore 79094469703 ELECTRIC RANGE
Kenmore 79094472800 ELECTRIC RANGE
Kenmore 79094472801 ELECTRIC RANGE
Kenmore 79094472802 ELECTRIC RANGE
Kenmore 79094472803 ELECTRIC RANGE
Kenmore 79094473800 ELECTRIC RANGE
Kenmore 79094473801 ELECTRIC RANGE
Kenmore 79094473802 ELECTRIC RANGE
Kenmore 79094473803 ELECTRIC RANGE
Kenmore 79094479800 ELECTRIC RANGE
  #2 (permalink)
Old 03-06-2014, 02:53 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Do not use graphite as it is a lubricant.
I would try putting some high temperature RTV on the screw threads.
It is available at most hardware/lumber stores (Home Depot etc.) and automotive supply stores. Check the label for the temperature range.
Clean the screw threads and the handle where the screw threads in with isopropyl alcohol to remove any oily deposits before applying the RTV.
If this does not work then I would purchase a new handle.
__________________
  #3 (permalink)
Old 03-16-2014, 06:08 PM
Junior Member
Default
Just tried it and it appears to have worked. Applied it and then let it go untouched for its cure time. After first bake I tried to tighten screw with my thumb and didnt budge. Thank you so much for your help.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Freezer door handle falls off revjohnc3 Refrigerator & Freezer Repair 1 04-18-2013 04:47 AM
Oven temp not right and door falls down. akd Oven Repair (including Ranges and Cooktops) 0 06-10-2010 11:28 PM
Gas oven intermittently shuts off, temperature falls Tombombadillo Oven Repair (including Ranges and Cooktops) 0 09-04-2009 11:44 AM
Oven Heat Some Time And Some Time Not mani Oven Repair (including Ranges and Cooktops) 1 04-29-2009 02:04 PM
BOSCH Oven Temperature Falls danthornton1 Oven Repair (including Ranges and Cooktops) 5 04-02-2009 02:23 PM
