For some reason the pilot light on my Estate gas oven won't light. Range works just fine. Cleaned the oven pilot opening; did not fix the problem. Thermocoupler appears to work because when I hold a lighter to the sensor gas will flow into the oven; however, I cannot get the oven to ignite manually either. Been working on this all day but no luck. Any suggestions?
