Discuss
Jenn-Aire Slide In Cooktop Elements Won't Heat
 in
I have a JES9750CAS00 30" Slide-in Electric Range with a downdraft fan. The cooktop cartridge on the right does not
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Jenn-Aire Slide In Cooktop Elements Won't Heat
  #1 (permalink)
Old 03-01-2014, 01:46 PM
Junior Member
joerodney is on a distinguished road
Default Jenn-Aire Slide In Cooktop Elements Won't Heat
Model Number: JES9750CAS00   Brand: Jenn-Air   Age: 1 - 5 years
I have a JES9750CAS00 30" Slide-in Electric Range with a downdraft fan. The cooktop cartridge on the right does not produce any heat on either cooking element (front or back). I believe the cartridge itself is OK, because it works fine when plugged into the left side of the cooktop. The problem seems to be on the right side only. I think the problem is in the plug in the back of the chassis that you plug the cartridge into. Or it could be in the control switch that you use to turn the elements on by turning the control knobs on the front.
What should I do to determine which is or what is the problem?
Is this one better left to a repairman to fix?
Related Models
Maytag JES9750CAS00 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9750CAS01 30" SLIDE-IN ELECTRIC RANGE
Jenn-Air JES9750CAS02 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9750CAW00 30" SLIDE-IN ELECTRIC RANGE
Jenn-Air JES9800AAB RANGE- S/C S/I DDRAFT ELE
Jenn-Air JES9800AAQ RANGE- S/C S/I DDRAFT ELE
Jenn-Air JES9800AAS RANGE- S/C S/I DDRAFT ELE
Jenn-Air JES9800AAW RANGE- S/C S/I DDRAFT ELE
Jenn-Air JES9800ACB RANGE- S/C S/I DDRAFT ELE
Jenn-Air JES9800ACS RANGE- S/C S/I DDRAFT ELE
Jenn-Air JES9800ACW RANGE- S/C S/I DDRAFT ELE
Jenn-Air JES9800BAB RANGE- S/C S/I DDRAFT ELE
Jenn-Air JES9800BAF RANGE- S/C S/I DDRAFT ELE
Jenn-Air JES9800BAS RANGE- S/C S/I DDRAFT ELE
Maytag JES9800BAS18 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9800CAB00 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9800CAB17 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9800CAF00 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9800CAF17 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9800CAR00 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9800CAS00 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9800CAS01 30" SLIDE-IN ELECTRIC RANGE
Jenn-Air JES9860AAB RANGE- S/C S/I DDRAFT ELE
Jenn-Air JES9860AAS RANGE- S/C S/I DDRAFT ELE
Jenn-Air JES9860AAW RANGE- S/C S/I DDRAFT ELE
Jenn-Air JES9860ACB RANGE- S/C S/I ELE
Jenn-Air JES9860ACS RANGE- S/C S/I ELE
Jenn-Air JES9860ACW RANGE- S/C S/I ELE
Jenn-Air JES9860BAB RANGE- S/C S/I DDRAFT ELE
Maytag JES9860BAB18 30" SLIDE-IN ELECTRIC RANGE
Jenn-Air JES9860BAS RANGE- S/C S/I DDRAFT ELE
Maytag JES9860BAS19 SLIDE-IN ELECTRIC RANGE
Jenn-Air JES9860BAW RANGE- S/C S/I DDRAFT ELE
Maytag JES9860BAW18 30" SLIDE-IN ELECTRIC RANGE
Jenn-Air JES9860BCB RANGE- S/C S/I DDRAFT ELE
Jenn-Air JES9860BCS RANGE- S/C S/I DDRAFT ELE
Jenn-Air JES9860BCW RANGE- S/C S/I DDRAFT ELE
Maytag JES9860CAB00 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9860CAS00 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9860CAS01 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9860CAW00 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9860CCB00 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9860CCS00 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9860CCS01 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9860CCW00 30" SLIDE-IN ELECTRIC RANGE
Jenn-Air JES9900BAB RANGE- S/C S/I DDRAFT ELE
Maytag JES9900BAB19 30" SLIDE-IN ELECTRIC RANGE
Jenn-Air JES9900BAF RANGE- S/C S/I DDRAFT ELE
Maytag JES9900BAF18 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9900BAF19 30" SLIDE-IN ELECTRIC RANGE
Jenn-Air JES9900BAS RANGE- S/C S/I DDRAFT ELE
Maytag JES9900BAS20 30" SLIDE-IN ELECTRIC RANGE
Jenn-Air JES9900BCB RANGE- S/C S/I DDRAFT ELE
Maytag JES9900BCB20 30" SLIDE-IN ELECTRIC RANGE
Jenn-Air JES9900BCS RANGE- S/C S/I DDRAFT ELE
Maytag JES9900BCS21 30" SLIDE-IN ELECTRIC RANGE
Jenn-Air JES9900BCW RANGE- S/C S/I DDRAFT ELE
Maytag JES9900BCW20 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9900CCB00 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9900CCS00 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9900CCS01 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9900CCW00 30" SLIDE-IN ELECTRIC RANGE
General Electric JET1050A1 Counter top microwave
General Electric JET1050Y4 Counter top microwave
General Electric JET1060A1 Counter top microwave
General Electric JET1060A2 Counter top microwave
General Electric JET107001 Counter top microwave
General Electric JET108001 Counter top microwave
General Electric JET1110Y4 Counter top microwave
General Electric JET1120A1 Counter top microwave
General Electric JET1120A2 Counter top microwave
General Electric JET114001 Counter top microwave
General Electric JET1300A1 Counter top microwave
General Electric JET200001 Counter top microwave
General Electric JET200002 Counter top microwave
General Electric JET200003 Counter top microwave
General Electric JET200004 Counter top microwave
General Electric JET202001 Counter top microwave
General Electric JET2020D1 Counter top microwave
General Electric JET2020D2 Counter top microwave
General Electric JET2020D3 Counter top microwave
General Electric JET2020D4 Counter top microwave
General Electric JET203001 Counter top microwave
General Electric JET203002 Counter top microwave
General Electric JET203003 Counter top microwave
General Electric JET204001 Counter top microwave
General Electric JET208001 Counter top microwave
General Electric JET208002 Counter top microwave
General Electric JET208003 Counter top microwave
General Electric JET209001 Counter top microwave
General Electric JET2090D1 Counter top microwave
General Electric JET2090D2 Counter top microwave
General Electric JET2090D3 Counter top microwave
General Electric JET2090D4 Counter top microwave
General Electric JET210001 Counter top microwave
General Electric JET210002 Counter top microwave
General Electric JET210003 Counter top microwave
General Electric JET210004 Counter top microwave
General Electric JET211001 Counter top microwave
General Electric JET211002 Counter top microwave
General Electric JET2110H1 Counter top microwave
General Electric JET212001 Counter top microwave
General Electric JET212002 Counter top microwave
General Electric JET2120H1 Counter top microwave
General Electric JET213001 Counter top microwave
General Electric JET213002 Counter top microwave
General Electric JET214001 Counter top microwave
General Electric JET214002 Counter top microwave
General Electric JET220001 Counter top microwave
General Electric JET220002 Counter top microwave
General Electric JET220003 Counter top microwave
General Electric JET230001 Counter top microwave
General Electric JET230002 Counter top microwave
General Electric JET235001 Counter top microwave
General Electric JET235002 Counter top microwave
General Electric JET235003 Counter top microwave
General Electric JET320001 Counter top microwave
General Electric JET322001 Counter top microwave
General Electric JET322G01 Counter top microwave
General Electric JET322H01 Counter top microwave
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Jenn-Aire Cooktop element doesn't heat JimGagnepain Oven Repair (including Ranges and Cooktops) 5 07-08-2010 03:21 PM
jenn-aire electric cooktop carl diedrich Oven Repair (including Ranges and Cooktops) 8 04-17-2010 04:17 PM
jenn-aire electric cooktop carl diedrich Oven Repair (including Ranges and Cooktops) 0 04-08-2010 08:19 AM
Jenn-Aire Electric Downdraft Slide-In Range Judith Yeiser Oven Repair (including Ranges and Cooktops) 1 07-08-2009 11:02 AM
Jenn Aire Glass cooktop( ramtough Oven Repair (including Ranges and Cooktops) 0 01-11-2009 11:52 AM
