Discuss
remove glasstop range glued to granite counter
 in
I need to remove my glass top which was unfortunately GLUED (not strapped) to the granite counter when it was
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » remove glasstop range glued to granite counter
  #1 (permalink)
Old 02-27-2014, 12:23 PM
Junior Member
geri reinardy is on a distinguished road
Default remove glasstop range glued to granite counter
Brand: Jenn-Air   Age: More than 10 years
I need to remove my glass top which was unfortunately GLUED (not strapped) to the granite counter when it was installed! Infinite switch needs to be replaced under homeowners warranty. (Switch repair company won't remove glass top for fear of breaking it.) Can the glass top be removed without breaking or will I most likely have to replace the entire unit?
  #2 (permalink)
Old 02-27-2014, 06:14 PM
Member
festeraddams is on a distinguished road
Default
Take a small putty knife and force it under the glass all the way around, this will cut the putty (I have done that a time or two, but depending upon the conditions I have refused a few myself....) If the glass is cracked I wont mess with them at all......
  #3 (permalink)
Old 02-28-2014, 05:11 AM
Junior Member
Default
Thanks! Will try that.
  #4 (permalink)
Junior Member
Default
  #5 (permalink)
Old 10-23-2014, 11:25 PM
Junior Member
alexlai is on a distinguished road
Default
When you have glass counter, there will be a probability of cracking. I think you should call professionals, they might be having experience in doing such glass counter removal. Also keep measurements correctly while installing granite slab as there are difference in glass and granite structure.
Granite Direct Inc
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Remove Maytag Range GlassTop, How to BobYates Oven Repair (including Ranges and Cooktops) 4 06-10-2012 08:12 PM
Remove dishwasher from under counter Lucianp Dishwasher Repair 1 11-09-2011 08:31 AM
How to change the glasstop of GE range tabfannin100 Oven Repair (including Ranges and Cooktops) 1 05-21-2010 02:35 PM
Replace Glasstop GE Range rheiser Oven Repair (including Ranges and Cooktops) 3 03-20-2008 05:19 AM
How do I remove my trash compactor, so I can change counter monicaacevedo Garbage Disposer Repair 3 11-06-2007 11:47 AM
