Ranges are working fine on my gas stove but the oven doesn't. The display is fine but the oven is not firing up. I checked the igniter and the safety valve and the "Ohm reading" is O.K. The problem is on a control board. One of the two resistors aligned with the thermostat wires burned out so I would like to replace it. Is it worth the effort? Any advice? Thanks, Bob
