Discuss
GE "locked door" flashing, FC error code
 in
Thought I'd share my experience with this issue. 1. "locked door" flashing on control panel 2. after cycling breaker an
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » GE "locked door" flashing, FC error code
  #1 (permalink)
Old 02-23-2014, 07:39 PM
Junior Member
davemoore78613 is on a distinguished road
Default GE "locked door" flashing, FC error code
Model Number: JGB605   Brand: GE   Age: 1 - 5 years
2. after cycling breaker an error code FC appeared on control panel as well. Looking this code up says "check door lock circuit".
3. I found elsewhere on this blog and at GE a contrl panel button sequence that supposedly sometimes clears this issue - repeated tries did not work for me.
4. I used a VOM to make sure I got the correct resistances across the 2 switches on the door lock device and they were ok (one being low resistance and the other infinite resistance) meaning one swich was closed and the other open as was expected.
5. I replaced the door lock mechanism. Didn't fix it (I should not have wasted my money).
6. Ok, so has to be the controller right? Wrong - that didn't fix it either (this surprised me).
7. Ok, so it has to be wiring then, Sure enough, when I measured the resistance between the 2 non-common wires that run to the door lock switches they had 3 ohms resistance between them! (this should have been infinite resistance). I went ahead and fished thru 3 new wires for the door lock switch and viola! - problem gone. BTW, do not use just any wire - make sure you get THHN high temperature wire!
Moral of the story - try the control panel unlock sequence first. Next, carefully check the 3 wires of the door lock circuit for shorts between them and shorts to ground (short to the stove metal body). If the wiring is good and the door lock switches ring out good then it is probably the controller.
Hope this helps someone...
Dave
Related Models
General Electric JGB605DET1BB GAS RANGE
General Electric JGB605DET1WW GAS RANGE
General Electric JGB605SET1SS GAS RANGE
General Electric JGB800DEP1BB GAS RANGE
General Electric JGB800DEP1CC GAS RANGE
General Electric JGB800DEP1WW GAS RANGE
General Electric JGB800DEP2BB GAS RANGE
General Electric JGB800DEP2CC GAS RANGE
General Electric JGB800DEP2WW GAS RANGE
General Electric JGB800SEP1SS GAS RANGE
General Electric JGB800SEP2SS GAS RANGE
General Electric JGB805DEP1BB GAS RANGE
General Electric JGB805DEP1WW GAS RANGE
General Electric JGB805DEP2BB GAS RANGE
General Electric JGB805DEP2WW GAS RANGE
General Electric JGB805DEP3BB GAS RANGE
General Electric JGB805DEP3WW GAS RANGE
General Electric JGB805SEP1SS GAS RANGE
General Electric JGB805SEP2SS GAS RANGE
General Electric JGB805SEP3SS GAS RANGE
General Electric JGB80XSER1SS GAS RANGE
General Electric JGB810DEP1BB GAS RANGE
General Electric JGB810DEP1CC GAS RANGE
General Electric JGB810DEP1WW GAS RANGE
General Electric JGB810DEP2BB GAS RANGE
General Electric JGB810DEP2CC GAS RANGE
General Electric JGB810DEP2WW GAS RANGE
General Electric JGB810DET1BB GAS RANGE
General Electric JGB810DET1CC GAS RANGE
General Electric JGB810DET1WW GAS RANGE
General Electric JGB810SEP1SS GAS RANGE
General Electric JGB810SEP2SS GAS RANGE
General Electric JGB810SET1SS GAS RANGE
General Electric JGB820DEP1BB GAS RANGE
General Electric JGB820DEP1WW GAS RANGE
General Electric JGB820DEP2BB GAS RANGE
General Electric JGB820DEP2WW GAS RANGE
General Electric JGB820SEP1SS GAS RANGE
General Electric JGB820SEP2SS GAS RANGE
General Electric JGB840SET1SS GAS RANGE
General Electric JGB870DET1BB GAS RANGE
General Electric JGB870DET1WW GAS RANGE
General Electric JGB870SET1SS GAS RANGE
General Electric JGB900BEF1BB Gas range
General Electric JGB900BEF2BB Gas range
General Electric JGB900BEF3BB Gas range
General Electric JGB900BEK1BB Gas range
General Electric JGB900BEK2BB Gas range
General Electric JGB900BEK3BB Gas range
General Electric JGB900BEK4BB Gas range
General Electric JGB900BEK5BB Gas range
General Electric JGB900BEK6BB Gas range
General Electric JGB900BEK7BB GAS RANGE
General Electric JGB900CEF1CC Gas range
General Electric JGB900CEF2CC Gas range
General Electric JGB900CEF3CC Gas range
General Electric JGB900CEK1CC Gas range
General Electric JGB900CEK2CC Gas range
General Electric JGB900CEK3CC Gas range
General Electric JGB900CEK4CC Gas range
General Electric JGB900CEK5CC Gas range
General Electric JGB900CEK6CC Gas range
General Electric JGB900CEK7CC GAS RANGE
General Electric JGB900SEF1SS Gas range
General Electric JGB900SEF2SS Gas range
General Electric JGB900SEF3SS Gas range
General Electric JGB900SEK1SS Gas range
General Electric JGB900SEK2SS Gas range
General Electric JGB900SEK3SS Gas range
General Electric JGB900SEK4SS Gas range
General Electric JGB900SEK5SS Gas range
General Electric JGB900SEK6SS Gas range
General Electric JGB900SEL1SS Gas range
General Electric JGB900SEL2SS GAS RANGE
General Electric JGB900SEP1SS GAS RANGE
General Electric JGB900SEP2SS GAS RANGE
General Electric JGB900WEF1WW Gas range
General Electric JGB900WEF2WW Gas range
General Electric JGB900WEF3WW Gas range
General Electric JGB900WEK1WW Gas range
General Electric JGB900WEK2WW Gas range
General Electric JGB900WEK3WW Gas range
General Electric JGB900WEK4WW Gas range
General Electric JGB900WEK5WW Gas range
General Electric JGB900WEK6WW Gas range
General Electric JGB900WEK7WW GAS RANGE
General Electric JGB902BEH1BB Gas range
General Electric JGB902BEH2BB Gas range
General Electric JGB902BEH3BB Gas range
General Electric JGB902CEH1CC Gas range
General Electric JGB902CEH2CC Gas range
General Electric JGB902CEH3CC Gas range
General Electric JGB902SEH1SS Gas range
General Electric JGB902SEH2SS Gas range
General Electric JGB902SEH3SS Gas range
General Electric JGB902WEH1WW Gas range
General Electric JGB902WEH2WW Gas range
General Electric JGB902WEH3WW Gas range
General Electric JGB905BEF1BB Gas range
General Electric JGB905BEF2BB Gas range
General Electric JGB905BEF3BB Gas range
General Electric JGB905CEF1CC Gas range
General Electric JGB905CEF2CC Gas range
General Electric JGB905CEF3CC Gas range
General Electric JGB905SEF1SS Gas range
General Electric JGB905SEF2SS Gas range
General Electric JGB905SEF3SS Gas range
General Electric JGB905WEF1WW Gas range
General Electric JGB905WEF2WW Gas range
General Electric JGB905WEF3WW Gas range
General Electric JGB908BEK1BB Gas range
General Electric JGB908BEK2BB Gas range
General Electric JGB908BEK3BB Gas range
General Electric JGB908BEK4BB Gas range
General Electric JGB908BEK5BB Gas range
General Electric JGB908BEK6BB GAS RANGE
General Electric JGB908BEK7BB GAS RANGE
General Electric JGB908BEK8BB GAS RANGE
General Electric JGB908BEK9BB GAS RANGE
General Electric JGB908CEK1CC Gas range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE double wall oven blinks "locked door" kmdinsd Oven Repair (including Ranges and Cooktops) 0 03-07-2013 04:12 PM
LG dishwasher flashing "LE" code and stops brian harsh Dishwasher Repair 0 01-21-2012 08:41 AM
Ge Oven "locked Door" Flashing GTS1211 Oven Repair (including Ranges and Cooktops) 0 11-21-2010 08:47 AM
amana stove flashed "locked and error code skattie28 Oven Repair (including Ranges and Cooktops) 0 07-04-2010 07:01 AM
Flashing "Er" Code / Frigidaire 4000 series dishwasher Tarfunk Dishwasher Repair 0 09-08-2009 03:54 PM
