| » Installing A Bake Element On An Oven |
Model Number: 3510PRW Brand: Magic Chef Age: More than 10 years
I WAS TRYING TO REPLACE THE BAKE ELEMENT ON MY MOTHERS OVEN SINCE WE CANT GET THE REPAIR GUY TO COME OUT HERE AND DO IT. WHEN I REMOVED THE ELEMENT ONLY ONE SIDE OF IT WAS CONNECTED TO A WIRE. I WAS WONDERING IF IT IS SUPPOSE TO BE LIKE THAT OR IS THAT SOME OF MY PROBLEM? I CAN GET THE REPLACEMENT PART EASILY BUT THE WIRING IS A LITTLE CONFUSING TO ME.
Related Models |
Replacement parts for MAGIC CHEF 3510PRW | AppliancePartsPros.com If there is only one side of the element connected that is the problem. Trouble is that you do not know if the connector came off while you were trying to remove the element. Check the element with a meter, usually around 10 ohms. Unplug the unit and try to fish the wire out of the back of the unit. If this does not work you will have to open up the back to get at the wire. Note that it should not have come off without a fair amount of resistance so be sure to check that the connector fits tightly onto the element and that the wire has not overheated and is corroded. Make sure to remove power from the unit, it runs on 240 volts which is lethal!!!
__________________
Thank You So Much For Your Help...that's What I Thought The Problem Is...the Other Problem Is The Connector Broke On The Element So I Have To Fish It Out The Back Of The Oven...once Again Thank You And I'll Make Sure To Cut All The Power To The Stove..:d
| Display Modes | |
| Oven Bake Element | Lenore Arquette | Oven Repair (including Ranges and Cooktops) | 1 | 04-13-2009 05:43 PM |
| GE oven bake element out | luvmycompu@aol.com | Oven Repair (including Ranges and Cooktops) | 1 | 01-15-2009 10:59 PM |
| Installing bake element | MRiggio | Oven Repair (including Ranges and Cooktops) | 1 | 12-11-2008 06:40 PM |
| Oven Bake Element | topgon05 | Oven Repair (including Ranges and Cooktops) | 0 | 04-05-2008 08:17 AM |
| Oven bake element | jas1000 | Oven Repair (including Ranges and Cooktops) | 4 | 12-27-2007 04:03 PM |
