I have a Maytag CRE9800ACE and the highest the temperature will get to is 225 degrees. The oven thinks it is at the correct temperature, but it is not. I have replaced the temperature sensor and that did not resolve the problem, so I am left with the electronic control board. This part is next to impossible to find (7601P200-60) but I have located a control board from the CRE9600 model (7601P292-60). Will the 7601P292-60 board work in my CRE9800? The only difference I can see is the P200 model has a turn knob for adjusting settings but the P292 model has up/down buttons.
Any help would be greatly appreciated! The item I found is on ******** from a seller with 99% rating so the sooner I can figure this out the better, before the item is gone!
