Discuss
Frigidaire oven, clock display does not work
 in
I have a frigidaire range the top elements work however, the oven and clock etc does not work. What do
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Frigidaire oven, clock display does not work
  #1 (permalink)
Old 02-19-2014, 05:47 AM
Junior Member
khalim is on a distinguished road
Default Frigidaire oven, clock display does not work
Brand: Frigidaire   Age: 1 - 5 years
I have a frigidaire range the top elements work however, the oven and clock etc does not work. What do you think is the problem and how do I go about repairing it.
Thank you.
  #2 (permalink)
Old 02-20-2014, 12:54 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
A model number may help others help you.
What do you mean when you say that the oven control does not work re: no signs of life, temperature is off etc.
Does the oven light work or anything else that runs off of 120 volts instead of the 240 volts that is used for powering the elements.
The control board also needs 120 volts so if the oven light is also off it could be a power problem.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Burners work oven won't turn on and no display on clock Tuna2311 Oven Repair (including Ranges and Cooktops) 0 05-21-2012 06:00 AM
Oven doesn't shut off, Ignitors doesn't work, Can't see the clock display jcpcac Oven Repair (including Ranges and Cooktops) 0 10-03-2011 11:45 AM
Frigidaire does not work display blinking Ashok21 Dishwasher Repair 5 08-03-2011 03:13 PM
Clock display and oven not working Jenny1974 Oven Repair (including Ranges and Cooktops) 0 07-14-2010 10:20 AM
No clock or oven display Axlelift Oven Repair (including Ranges and Cooktops) 1 01-05-2010 03:48 PM
