Discuss
Oven bake element staying on ..
 in
I just replaced the lower bake element and I put the over on 250 and let it warm up, after
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven bake element staying on ..
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 02-18-2014, 08:23 AM
Junior Member
Edplu is on a distinguished road
Default Oven bake element staying on ..
Model Number: Fep210ewo   Brand: Whirlpool   Age: More than 10 years
I just replaced the lower bake element and I put the over on 250 and let it warm up, after abt 5 mins or so I looked in the oven and the element was still red hot. Then I turned the oven down to 100 and the element when down. I then put it on 400 and waited abt 10-15 mins, looked inside and the element was still red hot. Turned temp down to 250 and waited to see it the element would kick down and it looked like it did not ... I;m not sure but I think the element is not shuting down when it reached the temp. I am asuming this is how it should work ?? The element should cycle when it reaches the right temp ?? Could this be a bad temp control ?? also will this burn out the new element if not fixed ?? Please help .. any info ..thx How do I test the oven control .. temp sensor wire from the control ??
Related Models
Roper FEP210KN0 ELECTRIC RANGE
Roper FEP210KQ0 ELECTRIC RANGE
Roper FEP210KQ1 20" ELECTRIC FREESTANDING RANGE STANDARD CLEAN OVEN
Roper FEP210KW0 ELECTRIC RANGE
Whirlpool FEP210VL0
Whirlpool FEP210VL1
Whirlpool FEP210VL2
Roper FEP210VL4 Ranges, Electric*
Whirlpool FEP210VL6 ELECTRIC RANGES & OVENS
Roper FEP210VW0 Ranges, Electric*
Roper FEP210VW1 Ranges, Electric*
Roper FEP210VW2 Ranges, Electric*
Roper FEP210VW3 Ranges, Electric*
Roper FEP210VW4 Ranges, Electric*
Roper FEP210VW5 Ranges, Electric*
Whirlpool FEP210VW6 ELECTRIC RANGES & OVENS
Roper FEP310BL0 30" ELECTRIC FREESTANDING CONVENTIONAL RANGE
Roper FEP310BL1 30" ELECTRIC FREESTANDING CONVENTIONAL RANGE
Roper FEP310BW0 30" ELECTRIC FREESTANDING CONVENTIONAL RANGE
Roper FEP310BW1 30" ELECTRIC FREESTANDING CONVENTIONAL RANGE
Roper FEP310EN0 ELECTRIC RANGE
Roper FEP310EN1 ELECTRIC RANGES AND OVENS
Roper FEP310EW0 ELECTRIC RANGE
Roper FEP310EW1 ELECTRIC RANGES AND OVENS
Roper FEP310GN0 30" ELECTRIC FREESTANDING RANGE
Roper FEP310GN1 ELECTRIC RANGE
Roper FEP310GW0 30" ELECTRIC FREESTANDING RANGE
Roper FEP310GW1 ELECTRIC RANGE
Roper FEP310KN0 ELECTRIC RANGE
Roper FEP310KN1 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Roper FEP310KV1 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Roper FEP310KV2 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Roper FEP310KV3 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Roper FEP310KV4 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Roper FEP310KW0 ELECTRIC RANGE
Roper FEP310KW1 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Roper FEP310KW2 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Roper FEP310KW3 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Roper FEP310KW4 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Roper FEP310KW5 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Roper FEP310KW6 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Roper FEP310VQ0 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Roper FEP310VW0 Ranges, Electric*
Roper FEP310VW1 Ranges, Electric*
Roper FEP310YW0 Ranges, Electric*
Roper FEP310YW1 Ranges, Electric*
Roper FEP310YW2 Ranges, Electric*
Roper FEP314BL0 30" ELECTRONIC RANGE / OVEN
Roper FEP314BW0 30" ELECTRONIC RANGE / OVEN
Roper FEP320BL0 ELECTRIC RANGE
Roper FEP320BL1 ELECTRIC RANGE
Roper FEP320BW0 ELECTRIC RANGE
Roper FEP320BW1 ELECTRIC RANGE
Roper FEP320EN0 ELECTRIC RANGE
Roper FEP320EN1 ELECTRIC RANGE
Roper FEP320EW0 ELECTRIC RANGE
Roper FEP320EW1 ELECTRIC RANGE
Roper FEP320GN0 ELECTRIC RANGE
Roper FEP320GN1 ELECTRIC RANGE
Roper FEP320GW0 ELECTRIC RANGE
Roper FEP320GW1 ELECTRIC RANGE
Roper FEP320KN0 ELECTRIC RANGE
Roper FEP320KN1 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Roper FEP320KW0 ELECTRIC RANGE
Roper FEP320KW1 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Roper FEP320VW0 ELECTRIC RANGE
Roper FEP320YW0 ELECTRIC RANGE
Roper FEP320YW1 ELECTRIC RANGE
Roper FEP320YW2 ELECTRIC RANGE
Roper FEP330BL0 30" ELECTRIC FREESTANDING CONVENTIONAL RANGE
Roper FEP330BL1 30" ELECTRIC FREESTANDING CONVENTIONAL RANGE
Roper FEP330BQ0 30" ELECTRIC FREESTANDING CONVENTIONAL RANGE
Roper FEP330BQ1 30" ELECTRIC FREESTANDING CONVENTIONAL RANGE
Roper FEP330BW0 30" ELECTRIC FREESTANDING CONVENTIONAL RANGE
Roper FEP330BW1 30" ELECTRIC FREESTANDING CONVENTIONAL RANGE
Roper FEP330EN0 ELECTRIC RANGE
Roper FEP330EN1 ELECTRIC RANGES AND OVENS
Roper FEP330EQ0 ELECTRIC RANGE
Roper FEP330EQ1 ELECTRIC RANGES AND OVENS
Roper FEP330EW0 ELECTRIC RANGE
Roper FEP330EW1 ELECTRIC RANGES AND OVENS
Roper FEP330GN0 30" ELECTRIC FREESTANDING RANGE
Roper FEP330GN1 ELECTRIC RANGE
Roper FEP330GQ0 30" ELECTRIC FREESTANDING RANGE
Roper FEP330GQ1 ELECTRIC RANGE
Roper FEP330GW0 30" ELECTRIC FREESTANDING RANGE
Roper FEP330GW1 ELECTRIC RANGE
Roper FEP330KN0 ELECTRIC RANGE
Roper FEP330KN1 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Roper FEP330KQ0 ELECTRIC RANGE
Roper FEP330KQ1 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Roper FEP330KW0 ELECTRIC RANGE
Roper FEP330KW1 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Roper FEP330VW0 Ranges, Electric
Roper FEP330VW1 Ranges, Electric
Roper FEP330YW0 Ranges, Electric
Roper FEP330YW1 Ranges, Electric
Roper FEP330YW2 Ranges, Electric
Roper FEP340VW0 Ranges, Electric*
Roper FEP340YW0 Ranges, Electric*
Roper FEP340YW1 Ranges, Electric*
Roper FEP350BL0 30" ELECTRIC FREESTANDING CONVENTIONAL RANGE
Roper FEP350BW0 30" ELECTRIC FREESTANDING CONVENTIONAL RANGE
Roper FEP350BW1 30" ELECTRIC FREESTANDING CONVENTIONAL RANGE
Roper FEP350VW0 Ranges, Electric*
Roper FEP350YW0 Ranges, Electric*
Roper FEP350YW1 Ranges, Electric*
Roper FEP350YW2 Ranges, Electric*
Frigidaire FEQ1442CES0 Frigidaire/dryer
Frigidaire FEQ1442CES1 DRYER
Frigidaire FEQ1442ES0 Frigidaire/dryer
Frigidaire FEQ1442ES1 DRYER
Frigidaire FEQ1442FE0 DRYER
Frigidaire FEQ1452CKS0 ELECTRIC DRYER
Frigidaire FEQ1452HE0 DRYER
Frigidaire FEQ1452HS0 DRYER
Frigidaire FEQ332CES0 Frigidaire/dryer
Frigidaire FEQ332ES0 Frigidaire/dryer
Frigidaire FEQ5000HS0 DRYER
Frigidaire FEQB2152FE0 Frigidaire/dryer
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
oven bake element carguy50 Oven Repair (including Ranges and Cooktops) 1 02-23-2012 05:01 PM
oven bake element jane braun Oven Repair (including Ranges and Cooktops) 0 11-23-2011 01:28 PM
Oven bake/broil not working after bake element replacement J Justin Oven Repair (including Ranges and Cooktops) 1 11-05-2009 04:36 PM
Oven Bake Element Lenore Arquette Oven Repair (including Ranges and Cooktops) 1 04-13-2009 04:43 PM
Oven Bake Element topgon05 Oven Repair (including Ranges and Cooktops) 0 04-05-2008 07:17 AM
