Link to JTP86BFBB Hi. I'm at a loss here. I simply replaced the oven light bulb and now I have no power to the unit/control panel. When I screwed in the new bulb, everything worked fine. I turned the bulb on and off a few times using the button on the control panel. When I replaced the glass cover the control panel went dark. What I've tried so far: 1. Checked the house breaker (was fine) 2. Tried flipping the breaker a few times (nothing) 3. Tried flipping the breaker slowly a few times (nothing - read that by doing this could regain a lost neutral that may not have popped breaker) 4. Tried removing cover & bulb and re-setting breaker (nothing) 5. Tried re-installing bulb without cover and re-setting breaker (nothing) I would hate to think that simply replacing the bulb would burn out the control panel. Any insight on this would be greatly appreciated. Thank You.
