Discuss
f-30 error code
 in
often beeps and throws error code f-30 sometime even when not in use? It also seems to shut off as
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » f-30 error code
  #1 (permalink)
Old 02-17-2014, 09:13 AM
Junior Member
Joe mN is on a distinguished road
Default f-30 error code
Model Number: GLES389ESA   Brand: Frigidaire   Age: 5 - 10 years
often beeps and throws error code f-30 sometime even when not in use? It also seems to shut off as if it over heated....we can wait 10-15 minutes and try it again...usually works ok the second time......
The cooktop always works..just the oven is affected...
We re-leveled the unit and double checked the wiring connections to make sure nothing was loose or insuficient voltage...all seemed ok .
Should I replace the control pc board?
What do you suggest?
Related Models
Frigidaire GLES389ESA Frigidaire/electric Range
Frigidaire GLES389ESB Frigidaire/electric Range
Frigidaire GLES389ESC Frigidaire/electric Range
Frigidaire GLES389ESD Frigidaire/electric Range
Frigidaire GLES389ESE Frigidaire/electric Range
Frigidaire GLES389FBA Frigidaire/electric Range
Frigidaire GLES389FBB Frigidaire/electric Range
Frigidaire GLES389FBC ELECTRIC RANGE
Frigidaire GLES389FBD ELECTRIC RANGE
Frigidaire GLES389FBE ELECTRIC RANGE
Frigidaire GLES389FBF ELECTRIC RANGE
Frigidaire GLES389FQA Frigidaire/electric Range
Frigidaire GLES389FQB Frigidaire/electric Range
Frigidaire GLES389FSA Frigidaire/electric Range
Frigidaire GLES389FSB Frigidaire/electric Range
Frigidaire GLES389FSC ELECTRIC RANGE
Frigidaire GLES389FSD ELECTRIC RANGE
Frigidaire GLES389FSE ELECTRIC RANGE
Frigidaire GLET1031CS0 Frigidaire/laundry Center
Frigidaire GLET1031FS0 Frigidaire/laundry Center
Frigidaire GLET1031FS1 LAUNDRY CENTER
Frigidaire GLET1031FS2 LAUNDRY CENTER
Frigidaire GLET1031FS4 LAUNDRY CENTER
Frigidaire GLET1041AS0 Lc - Frig Gallery
Frigidaire GLET1041AS1 Lc - Frig Gallery
Frigidaire GLET1041AS2 Frigidaire/laundrycenter
Frigidaire GLET1142CS0 Frigidaire/laundry Center
Frigidaire GLET1142FS0 Frigidaire/laundry Center
Frigidaire GLET1142FS1 LAUNDRY CENTER
Frigidaire GLET1142FS2 LAUNDRY CENTER
Frigidaire GLFC1326FW0 Frigidaire/freezer
Frigidaire GLFC1326FW1 Frigidaire/freezer
Frigidaire GLFC1326FW2 FREEZER
Frigidaire GLFC1326FW3 FREEZER
Frigidaire GLFC1526FW0 Frigidaire/freezer
Frigidaire GLFC1526FW1 Frigidaire/freezer
Frigidaire GLFC1526FW2 FREEZER
Frigidaire GLFC1526FW3 FREEZER
Frigidaire GLFC1526FW4 FREEZER
Frigidaire GLFC1526FW5 FREEZER
Frigidaire GLFC1526FW6 FREEZER
Frigidaire GLFC1526FW7 FREEZER
Frigidaire GLFC2027FW0 Frigidaire/freezer
Frigidaire GLFC2027FW1 Frigidaire/freezer
Frigidaire GLFC2027FW2 Frigidaire/freezer
Frigidaire GLFC2027FW3 Frigidaire/freezer
Frigidaire GLFC2027FW4 FREEZER
Frigidaire GLFC2027FW5 FREEZER
Frigidaire GLFC2027FW6 FREEZER
Frigidaire GLFC2528FW0 Frigidaire/freezer
Frigidaire GLFC2528FW1 Frigidaire/freezer
Frigidaire GLFC2528FW10 FREEZER
Frigidaire GLFC2528FW2 Frigidaire/freezer
Frigidaire GLFC2528FW3 Frigidaire/freezer
Frigidaire GLFC2528FW4 FREEZER
Frigidaire GLFC2528FW5 FREEZER
Frigidaire GLFC2528FW6 FREEZER
Frigidaire GLFC2528FW7 FREEZER
Frigidaire GLFC2528FW8 FREEZER
Frigidaire GLFC2528FW9 FREEZER
Frigidaire GLFH1467GW0 FREEZER
Frigidaire GLFH1467GW1 FREEZER
Frigidaire GLFH1767GW1 FREEZER
Frigidaire GLFH1779GW0 FREEZER
Frigidaire GLFH1779GW1 FREEZER
Frigidaire GLFH1779GW2 FREEZER
Frigidaire GLFH17F8HBA FREEZER
Frigidaire GLFH17F8HBB FREEZER
Frigidaire GLFH17F8HBC FREEZER
Frigidaire GLFH17F8HBD FREEZER
Frigidaire GLFH17F8HBF FREEZER
Frigidaire GLFH17F8HBG FREEZER
Frigidaire GLFH17F8HBH FREEZER
Frigidaire GLFH17F8HWA FREEZER
Frigidaire GLFH17F8HWB FREEZER
Frigidaire GLFH17F8HWC FREEZER
Frigidaire GLFH17F8HWD FREEZER
Frigidaire GLFH17F8HWE FREEZER
Frigidaire GLFH17F8HWF FREEZER
Frigidaire GLFH17F8HWG FRIGIDAIRE/FREEZER
Frigidaire GLFH17F8HWH FRIGIDAIRE/FREEZER
Frigidaire GLFH21F8HBA FREEZER
Frigidaire GLFH21F8HBB FREEZER
Frigidaire GLFH21F8HBC FREEZER
Frigidaire GLFH21F8HBD FREEZER
Frigidaire GLFH21F8HBE FREEZER
Frigidaire GLFH21F8HWA FREEZER
Frigidaire GLFH21F8HWB FREEZER
Frigidaire GLFH21F8HWC FREEZER
Frigidaire GLFH21F8HWD FREEZER
Frigidaire GLFH21F8HWE FREEZER
Frigidaire GLFH21F8HWG FREEZER
Frigidaire GLFN1326GW0 FREEZER
Frigidaire GLFN1326GW1 FREEZER
Frigidaire GLFN1326GW2 FREEZER
Frigidaire GLFN1326GW3 FREEZER
Frigidaire GLFU1467FW0 Frigidaire/freezer
Frigidaire GLFU1467FW1 FREEZER
Frigidaire GLFU1467FW2 FREEZER
Frigidaire GLFU1767FW2 Frigidaire/freezer
Frigidaire GLFU1767FW3 Frigidaire/freezer
Frigidaire GLFU1767FW4 Frigidaire/freezer
Frigidaire GLFU1767FW5 FREEZER
Frigidaire GLFU1767FW6 FREEZER
Frigidaire GLFU2067FW2 Frigidaire/freezer
Frigidaire GLFU2067FW3 Frigidaire/freezer
Frigidaire GLFU2067FW4 Frigidaire/freezer
Frigidaire GLFU2067FW5 FREEZER
Frigidaire GLFU2067FW6 FREEZER
Frigidaire GLFU2067FW7 FREEZER
Frigidaire GLFU2067FW8 FREEZER
Frigidaire GLGC30S8ABA Frigidaire/cooktop
Frigidaire GLGC30S8ABB Frigidaire/gas Cooktop
Frigidaire GLGC30S8AQA Frigidaire/cooktop
Frigidaire GLGC30S8AQB Frigidaire/gas Cooktop
Frigidaire GLGC30S8ASA Frigidaire/cooktop
Frigidaire GLGC30S8ASB Frigidaire/gas Cooktop
Frigidaire GLGC30S8CBA Frigidaire/gas Cooktop
Frigidaire GLGC30S8CBB Frigidaire/gas Cooktop
Frigidaire GLGC30S8CQA Frigidaire/gas Cooktop
  #2 (permalink)
Old 02-19-2014, 01:53 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Parts for Frigidaire GLES389ESA Range - AppliancePartsPros.com
F30 is an oven sensor problem.
I would check it.
It should be around 1,100 ohms at room temperature.
If OK then check where it connects to the control board.
Check for a cracked copper trail on the board.
Check for a cold solder joint at the connector.
Cold solder joints are often a duller silver color and may have pin holes.
Also gently wiggle the connector while watching the solder side to see if the connector legs move in the solder.
If all OK then I would replace the board.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
F1-8 Code, disconnected touchpad ribbon, then F1-7 error code sstark Oven Repair (including Ranges and Cooktops) 1 09-01-2014 09:41 AM
ERROR CODE F6E5 Cancel key error tammike Oven Repair (including Ranges and Cooktops) 8 08-06-2012 08:54 AM
Duet error code FH and diagnostic code C03 angelo78 Washer Repair 0 03-21-2012 08:12 AM
LG error code OE - drain error JPotter Washer Repair 0 04-01-2011 07:20 AM
frigidaire error code F10 - not listed in your error codes Skully26 Oven Repair (including Ranges and Cooktops) 2 02-16-2010 04:29 AM
