Discuss
Whirpool Oven Problems
 in
My Whirlpool double oven started out with a dim clock... then would shut off after the preheat mode... then the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Whirpool Oven Problems
  #1 (permalink)
Old 02-15-2014, 07:35 PM
Junior Member
phsffaman is on a distinguished road
Default Whirpool Oven Problems
Model Number: RBD245PDQ14   Brand: Whirlpool   Age: 5 - 10 years
My Whirlpool double oven started out with a dim clock... then would shut off after the preheat mode... then the clock went completely blank... then the ovens stopped working at all... the oven lights would still come on... I decided I'd replace the control board. I did, then I got the clock back on... a series of beeps and F5 E1. So I replaced the self clean motor/latch combo. Power up and get the same thing. I change the sister board. Power up and same thing. In the middle somewhere I got F2 E1. Right now if I power it up it will show PF power failure and the clock... in about 1 minutes it will beep and show F5 E1... in about 2 or 3 minutes it will beep and change to F2 E1 and stay. During the first minute after power up about half the buttons on the key pad will at least beep... the others will do nothing and neither oven will start. Unplug the keypad tail and it does the same routine. I'm in it $600... what now? Keypad?
Related Models
Whirlpool RBD245PDQ14 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD245PDQ15 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD245PDQ2 ELECTRIC OVEN
Whirlpool RBD245PDQ3 ELECTRIC OVEN
Whirlpool RBD245PDQ4 ELECTRIC OVEN
Whirlpool RBD245PDQ6 ELECTRIC OVEN
Whirlpool RBD245PDQ7 ELECTRIC OVEN
Whirlpool RBD245PDQ8 ELECTRIC OVEN
Whirlpool RBD245PDQ9 ELECTRIC OVEN
Whirlpool RBD245PDS12 ELECTRIC OVEN
Whirlpool RBD245PDS14 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD245PDS15 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD245PDT10 ELECTRIC OVEN
Whirlpool RBD245PDT11 ELECTRIC OVEN
Whirlpool RBD245PDT12 ELECTRIC OVEN
Whirlpool RBD245PDT14 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD245PDT15 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD245PDT8 ELECTRIC OVEN
Whirlpool RBD245PDT9 ELECTRIC OVEN
Whirlpool RBD245PRB00 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD245PRB02 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD245PRB03 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD245PRB04 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF
Whirlpool RBD245PRB05 24" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool RBD245PRQ00 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD245PRQ02 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD245PRQ03 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD245PRQ04 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF
Whirlpool RBD245PRQ05 24" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool RBD245PRS00 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD245PRS01 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD245PRS02 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD245PRS03 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD245PRS04 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF
Whirlpool RBD245PRS05 24" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool RBD245PRT00 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD245PRT02 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD245PRT03 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD245PRT04 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF
Whirlpool RBD245PRT05 24" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool RBD275PDB1 Built-In Oven, Electric
Whirlpool RBD275PDB10 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD275PDB11 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD275PDB12 OVEN
Whirlpool RBD275PDB13 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD275PDB14 27" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD275PDB15 27" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD275PDB2 Built-In Oven, Electric
Whirlpool RBD275PDB3 27" BUILT-IN ELECTRIC OVEN
Whirlpool RBD275PDB4 27" ELECTRIC DOUBLE OVEN
Whirlpool RBD275PDB6 27" ELECTRIC WALL OVEN
Whirlpool RBD275PDB7 BUILT-IN ELECTRIC OVEN
Whirlpool RBD275PDB8 ELECTRIC WALL OVEN
Whirlpool RBD275PDB9 BUILT-IN ELECTRIC OVEN
Whirlpool RBD275PDQ1 Built-In Oven, Electric
Whirlpool RBD275PDQ10 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD275PDQ11 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD275PDQ12 OVEN
Whirlpool RBD275PDQ13 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD275PDQ14 27" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD275PDQ15 27" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD275PDQ2 Built-In Oven, Electric
Whirlpool RBD275PDQ3 27" BUILT-IN ELECTRIC OVEN
Whirlpool RBD275PDQ4 27" ELECTRIC DOUBLE OVEN
Whirlpool RBD275PDQ6 27" ELECTRIC WALL OVEN
Whirlpool RBD275PDQ7 BUILT IN ELECTRIC OVEN
Whirlpool RBD275PDQ8 WALL OVEN
Whirlpool RBD275PDQ9 BUILT-IN ELECTRIC OVEN
Whirlpool RBD275PDS12 BUILT-IN DOUBLE OVEN, ELECTRIC
Whirlpool RBD275PDS14 27" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD275PDS15 27" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD275PDT10 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD275PDT11 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD275PDT12 OVEN
Whirlpool RBD275PDT13 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD275PDT14 27" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD275PDT15 27" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD275PDT8 BUILT-IN OVEN - ELECTRIC
Whirlpool RBD275PDT9 BUILT-IN OVEN - ELECTRIC
Whirlpool RBD275PRB00 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD275PRB02 27" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD275PRQ00 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD275PRQ02 27" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD275PRS00 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD275PRS01 27" BUILT-IN ELECTRIC DOUBLE OVEN CONVECTION-UPPER SELF-CLEAN (GOLD LINE)
Whirlpool RBD275PRS02 27" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD275PRT00 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD275PRT02 27" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD275PVB00 27" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD275PVB02 27" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF
Whirlpool RBD275PVB03 27" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool RBD275PVQ00 27" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD275PVQ02 27" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF
Whirlpool RBD275PVQ03 27" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool RBD275PVS00 27" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD275PVS02 27" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF
Whirlpool RBD275PVT00 27" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD275PVT02 27" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF
Whirlpool RBD275PVT03 27" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool RBD276PDB1 Built-In Oven, Electric
Whirlpool RBD276PDB10 OVEN
Whirlpool RBD276PDB11 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD276PDB12 OVEN
Whirlpool RBD276PDB2 Built-In Oven, Electric
Whirlpool RBD276PDB4 27" ELECTRIC DOUBLE OVEN
Whirlpool RBD276PDB6 27" BUILT-IN ELECTRIC OVEN
Whirlpool RBD276PDB7 BUILT-IN ELECTRIC OVEN
Whirlpool RBD276PDB8 BUILT-IN ELECTRIC OVEN
Whirlpool RBD276PDB9 OVEN
Whirlpool RBD276PDQ1 Built-In Oven, Electric
Whirlpool RBD276PDQ10 OVEN
Whirlpool RBD276PDQ11 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD276PDQ12 OVEN
Whirlpool RBD276PDQ2 Built-In Oven, Electric
Whirlpool RBD276PDQ4 27" ELECTRIC DOUBLE OVEN
Whirlpool RBD276PDQ6 27" BUILT-IN ELECTRIC OVEN
Whirlpool RBD276PDQ7 BUILT-IN ELECTRIC OVEN
Whirlpool RBD276PDQ8 BUILT-IN ELECTRIC OVEN
Whirlpool RBD276PDQ9 OVEN
Whirlpool RBD277PDB1 ELECTRIC OVEN
  #2 (permalink)
Old 02-24-2014, 07:52 PM
Junior Member
Default Finally working right!
Well, I was about to give up and admit defeat. I replaced the touch key pad and all is well! Both ovens work as new! I don't know why the code for the self cleaning door latch was being thrown. Turns out that was the only thing I replaced unneeded (was the door latch motor). I really think the control board/clock went out and after unplugging and plugging the key pad back to the new control board/clock, the key pad started acting up. Something I would suggest... don't use the self cleaning feature, EVER. I think the excessive heat needed to burn off food from the oven walls will toast the electronics...both the control board/clock and the touch key pad.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirpool Freezer Problems Eds 3rd Refrigerator & Freezer Repair 8 09-09-2013 05:06 AM
Whirpool Cycle Problems handymangarcia Dishwasher Repair 3 12-22-2012 09:10 PM
Whirpool cycle problems Dobbs Washer Repair 2 04-06-2011 04:51 PM
Whirpool Duet Gas Dryer control panel problems moeman12 Dryer Repair 3 02-28-2009 10:29 PM
Whirpool Duet Gas Dryer control panel problems moeman12 Dryer Repair 0 02-24-2009 06:41 PM
