I am needing help on diagnosing a problem with a Frigidaire oven. The oven is 6 to 8 years old. A few nights ago I turned on the oven to bake, in order to preheat it. A few minutes later I returned to find the broiler on. After several attempts to turn off the oven at the control panel (with no response from the oven, the broiler continued to heat), I began receiving a F3 code. The only way to turn off the broiler was to turn off the power at the breaker switch. Any idea on what is going on? I would assume a bad control panel.
Thanks in advance.
