I have a Thermador range that the igniter suddenly popped up out of the splash pan. Clearly a retaining clip has been shed. I thought I would unscrew the venture tube and release the burner base and then lift the splash pan and re-clip. I THOUGHT. The venture tubes do not break loose and I am wondering if there is any other means of fitting this dollar part. Thanks in advance.
