I have a GE class cook top that I am having trouble with maintaining the temperature on the dual-sized (front right) burner. If I have the temperature turned down to a low setting (1-3), the burner stays on too long and will generate enough heat to boil water. Does this generally require a replacement of the burner and sensor?
