Discuss
Jenn-air cooktop CCE3401B burner out
 in
I have a Jenn-Air CCE3401B cooktop that has a cracked glass that I am going to replace. This seems fairly
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Jenn-air cooktop CCE3401B burner out
  #1 (permalink)
Old 02-03-2014, 03:57 PM
Junior Member
davidmedlen is on a distinguished road
Default Jenn-air cooktop CCE3401B burner out
Model Number: CCE3401B   Brand: Jenn-Air   Age: 5 - 10 years
I have a Jenn-Air CCE3401B cooktop that has a cracked glass that I am going to replace. This seems fairly simple, I figured since I am getting in to the unit, I am going to go ahead and fix the back right burner that has not worked for the past 3 months.
I am not sure what parts I need to order, when I turn the know for this burner, the red indicator lights that surround the knob turn on. The burner itself does not turn on. Is this most likeley the burner or some other part / issue?
Thank you in advance for your recommendations!
Related Models
Jenn-Air CCE3401B SURFACE UNIT- ELE
Jenn-Air CCE3401Q SURFACE UNIT- ELE
Jenn-Air CCE3401W SURFACE UNIT- ELE
Jenn-Air CCE3450B SURFACE UNIT- ELE
Jenn-Air CCE3450W SURFACE UNIT- ELE
Jenn-Air CCE3451B SURFACE UNIT- ELE
Jenn-Air CCE3451W SURFACE UNIT- ELE
Jenn-Air CCE3530B SURFACE UNIT- ELE
Jenn-Air CCE3530W SURFACE UNIT- ELE
Jenn-Air CCE3531B SURFACE UNIT- ELE
Jenn-Air CCE3531W SURFACE UNIT- ELE
Jenn-Air CCE406 SURFACE UNIT- ELE
Jenn-Air CCE406B SURFACE UNIT- ELE
Jenn-Air CCE406L SURFACE UNIT- ELE
Jenn-Air CCE407B SURFACE UNIT- ELE
Jenn-Air CCE407B-C SURFACE UNIT- ELE
Jenn-Air CCE407W SURFACE UNIT- ELE
Jenn-Air CCE407W-C SURFACE UNIT- ELE
Maytag CCE6200ACB WALLOVEN- STD MWAVE ELE
Maytag CCE6200ACE WALLOVEN- STD MWAVE ELE
Maytag CCE700 WALLOVEN- S/C MWAVE ELE
Maytag CCE701 WALLOVEN- S/C MWAVE ELE
Jenn-Air CCE9300BF SURFACE UNIT- ELE
Jenn-Air CCE9300BG SURFACE UNIT- ELE
Jenn-Air CCE9300GG SURFACE UNIT- ELE
Jenn-Air CCE9300JD SURFACE UNIT- ELE
Jenn-Air CCE9300PL SURFACE UNIT- ELE
Jenn-Air CCE9300SL SURFACE UNIT- ELE
Jenn-Air CCE9300SS SURFACE UNIT- ELE
Jenn-Air CCE9300TG SURFACE UNIT- ELE
Maytag CCF200 FREEZER- CHEST
Jenn-Air CCG2420B SURFACE UNIT- GAS
Jenn-Air CCG2420W SURFACE UNIT- GAS
Jenn-Air CCG2421A SURFACE UNIT- GAS
Jenn-Air CCG2421B SURFACE UNIT- GAS
Jenn-Air CCG2421W SURFACE UNIT- GAS
Jenn-Air CCG2422B SURFACE UNIT- GAS
Jenn-Air CCG2422W SURFACE UNIT- GAS
Jenn-Air CCG2423B SURFACE UNIT- GAS
Jenn-Air CCG2423Q SURFACE UNIT- GAS
Jenn-Air CCG2423S SURFACE UNIT- GAS
Jenn-Air CCG2423W SURFACE UNIT- GAS
Jenn-Air CCG2520B SURFACE UNIT- GAS
Jenn-Air CCG2520W SURFACE UNIT- GAS
Jenn-Air CCG2521A SURFACE UNIT- GAS
Jenn-Air CCG2521B SURFACE UNIT- GAS
Jenn-Air CCG2521W SURFACE UNIT- GAS
Jenn-Air CCG2522B SURFACE UNIT- GAS
Jenn-Air CCG2522W SURFACE UNIT- GAS
Jenn-Air CCG2523B SURFACE UNIT- GAS
Jenn-Air CCG2523S SURFACE UNIT- GAS
Jenn-Air CCG2523W SURFACE UNIT- GAS
Jenn-Air CCG406B SURFACE UNIT- GAS
Jenn-Air CCG406L SURFACE UNIT- GAS
Jenn-Air CCG406S SURFACE UNIT- GAS
Jenn-Air CCG456B SURFACE UNIT- GAS
Jenn-Air CCG456W SURFACE UNIT- GAS
Jenn-Air CCG457B SURFACE UNIT- GAS
Jenn-Air CCG457W SURFACE UNIT- GAS
Jenn-Air CCG556B SURFACE UNIT- GAS
Jenn-Air CCG556W SURFACE UNIT- GAS
Jenn-Air CCGP2420P SURFACE UNIT- GAS
Jenn-Air CCGP2420PF SURFACE UNIT- GAS
Jenn-Air CCGP2420PG SURFACE UNIT- GAS
Jenn-Air CCGP2420PR SURFACE UNIT- GAS
Jenn-Air CCGP2420PU SURFACE UNIT- GAS
Jenn-Air CCGP2720P SURFACE UNIT- GAS
Jenn-Air CCGP2720PG SURFACE UNIT- GAS
Jenn-Air CCGP2720PK SURFACE UNIT- GAS
Jenn-Air CCGP2720PU SURFACE UNIT- GAS
Jenn-Air CCGP2820P SURFACE UNIT- GAS
Jenn-Air CCGP2820PR SURFACE UNIT- GAS
Jenn-Air CCGP2820PU SURFACE UNIT- GAS
Jenn-Air CCGX2420B SURFACE UNIT- GAS
Jenn-Air CCGX2420N GAS COOKTOP
Jenn-Air CCGX2420W SURFACE UNIT- GAS
Jenn-Air CCGX2620B SURFACE UNIT- GAS
Jenn-Air CCGX2620W SURFACE UNIT- GAS
Whirlpool CCH12AEK Commercial Icemaker
Whirlpool CCH12ASK Commercial Icemaker
Whirlpool CCH12WEK Commercial Icemaker
Whirlpool CCH12WSK Commercial Icemaker
Amana CCMA2000 COMMERCIAL MICROWAVES
Amana CCMA2000BK COMMERCIAL MICROWAVES
Amana CCMA2230 COMMERCIAL MICROWAVES
Jenn-Air CCP457B SURFACE UNIT- GAS
Jenn-Air CCP457W SURFACE UNIT- GAS
Jenn-Air CCP556B SURFACE UNIT- GAS
Jenn-Air CCP556W SURFACE UNIT- GAS
Jenn-Air CCR466B SURFACE UNIT- ELE
Jenn-Air CCR467B SURFACE UNIT- ELE
Jenn-Air CCR467B-C SURFACE UNIT- ELE
Jenn-Air CCR467W SURFACE UNIT- ELE
Jenn-Air CCR467W-C SURFACE UNIT- ELE
Jenn-Air CCR567B SURFACE UNIT- ELE
Jenn-Air CCR567B-C SURFACE UNIT- ELE
Jenn-Air CCR567W SURFACE UNIT- ELE
Jenn-Air CCR567W-C SURFACE UNIT- ELE
Jenn-Air CCS446 SURFACE UNIT- ELE
Jenn-Air CCS446-C SURFACE UNIT- ELE
Jenn-Air CCS446W SURFACE UNIT- ELE
Jenn-Air CCS446W-C SURFACE UNIT- ELE
Jenn-Air CCS447B SURFACE UNIT- ELE
Jenn-Air CCS447B-C SURFACE UNIT- ELE
Jenn-Air CCS447W SURFACE UNIT- ELE
Jenn-Air CCS447W-C SURFACE UNIT- ELE
Whirlpool CCS51AEL Ice Maker Kits
Amana CCU-514 RANGE- S/C S/I DDRAFT GAS
Amana CCU-516 RANGE- S/C S/I DDRAFT GAS
Thermador CCV36 COOKTOP
Whirlpool CCW2762EW0 COMMERCIAL WASHER
Whirlpool CCW5243W0
Whirlpool CCW5243W1
Whirlpool CCW5244W0
Whirlpool CCW5264EW0
Whirlpool CCW5264W1 COMMERCIAL WASHER
Whirlpool CCW5264W2
Whirlpool CCW5264W3
Whirlpool CCW5264W4
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Old Jenn Air Cooktop - 6 burner (3 cartridge) Norseman00 Oven Repair (including Ranges and Cooktops) 2 07-13-2011 09:36 AM
jenn-aire cooktop burner sputters olddaddy Oven Repair (including Ranges and Cooktops) 0 04-10-2011 06:30 PM
Jenn Air cooktop burner replacement help textex Oven Repair (including Ranges and Cooktops) 0 08-02-2010 10:39 AM
Jenn Air Electric Cooktop duel burner Gumphrey Smith Oven Repair (including Ranges and Cooktops) 1 07-07-2009 12:59 PM
Access to replace Jenn-Air Cooktop Burner jarepele Oven Repair (including Ranges and Cooktops) 1 05-29-2009 03:34 PM
