Discuss
Control Panel on Monogram Oven is Dark
 in
Hello, I have a GE Monogram oven that was purchased around 1997 that is no longer working. The model number
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Control Panel on Monogram Oven is Dark
  #1 (permalink)
Old 02-01-2014, 11:50 AM
Junior Member
MrChip is on a distinguished road
Question Control Panel on Monogram Oven is Dark
Model Number: ZET757WW1WW   Brand: GE   Age: More than 10 years
Hello,
I have a GE Monogram oven that was purchased around 1997 that is no longer working. The model number is ZET757WW1WW.
FYI We do not use the oven very often (average 2-3x a month), although the timer is used several times a day as an alarm.
A week ago I noticed the panel was completely dark - no error codes or lights of any kind. When I open the oven doors, the light does come on. So the oven is getting power. Here is what I tried so far and the results:
  1. Went to fuse box and turned the circuit breaker off for two minutes and then back on. Hoping this would reset the oven, but it did not happen.
  2. Tried pressing every key on the keypad - none of them made an audible beep.
  3. I opened up the unit and reset several of the connections, no luck. Some of the connections were very tight and I did not force the issue (concerned I would break something).
  4. Tried pressing two buttons at the same time (7 and 8) and nothing happened. I read somewhere that these two buttons reset the panel (not sure if it is for my model).
  5. Ignoring the fact that the panel is dark and the buttons do not beep - I tried turning both ovens on convection bake - still no response.
Based on what I have read on this website, I found two possible parts:
1. The oven control
- Part AP3426947
- URL: GE WB27T10277 Ovn Control - AppliancePartsPros.com
- Cost: $243.47
2. The panel control assembly.
- Part AP3160621
- URL: GE WB36T10507 Panel Control Assembly, White - AppliancePartsPros.com
- Cost: not available on APP, also could not find anywhere else
I called GE and they said they can send a repairman out for $100 service call. I have no idea what they would charge for parts and labor above that. Based on my symptoms, can anyone say what specific parts I would need?
Is there any way to tell if I need an new oven control or panel control? I would hate to buy the first one, install it, and find out the problem is not resolved.
How easy/difficult a DIY repair is this for a first time repairman?
Thanks in advance for your help. I hope this post wasn't too long or detailed.
Chip
Related Models
General Electric ZET757WW1WW Electric range
General Electric ZET757WW2WW Electric range
General Electric ZET837BB2BB Electric range
General Electric ZET837BB3BB Electric range
General Electric ZET837BBBB Electric range
General Electric ZET837BYBB Electric range
General Electric ZET837DB2SB Electric range
General Electric ZET837DB3SB Electric range
General Electric ZET837DBSB Electric range
General Electric ZET837DYSB Electric range
General Electric ZET837SB2SS Electric range
General Electric ZET837SB3SS Electric range
General Electric ZET837SBSS Electric range
General Electric ZET837SYSS Electric range
General Electric ZET837WB2WW Electric range
General Electric ZET837WB3WW Electric range
General Electric ZET837WBWW Electric range
General Electric ZET837WYWW Electric range
General Electric ZET857BB2BB Electric range
General Electric ZET857BB3BB Electric range
General Electric ZET857BBBB Electric range
General Electric ZET857BYBB Electric range
General Electric ZET857DB2SB Electric range
General Electric ZET857DB3SB Electric range
General Electric ZET857DBSB Electric range
General Electric ZET857DYSB Electric range
General Electric ZET857SB2SS Electric range
General Electric ZET857SB3SS Electric range
General Electric ZET857SBSS Electric range
General Electric ZET857SYSS Electric range
General Electric ZET857WB2WW Electric range
General Electric ZET857WB3WW Electric range
General Electric ZET857WBWW Electric range
General Electric ZET857WYWW Electric range
General Electric ZET938BF1BB Electric range
General Electric ZET938BF2BB Electric range
General Electric ZET938BF3BB Electric range
General Electric ZET938BF4BB Electric range
General Electric ZET938BF5BB Electric range
General Electric ZET938BF6BB Electric range
General Electric ZET938BM1BB ELECTRIC WALL OVEN
General Electric ZET938BM2BB ELECTRIC OVEN
General Electric ZET938SF1SS Electric range
General Electric ZET938SF2SS Electric range
General Electric ZET938SF3SS Electric range
General Electric ZET938SF4SS Electric range
General Electric ZET938SF5SS Electric range
General Electric ZET938SF6SS Electric range
General Electric ZET938SM1SS BUILT IN OVEN
General Electric ZET938SM2SS BUILT IN OVEN
General Electric ZET938WF1WW Electric range
General Electric ZET938WF2WW Electric range
General Electric ZET938WF3WW Electric range
General Electric ZET938WF4WW Electric range
General Electric ZET938WF5WW Electric range
General Electric ZET938WF6WW Electric range
General Electric ZET938WM1WW ELECTRIC WALL OVEN
General Electric ZET958BF1BB Electric range
General Electric ZET958BF2BB Electric range
General Electric ZET958BF3BB Electric range
General Electric ZET958BF4BB Electric range
General Electric ZET958BF5BB Electric range
General Electric ZET958BF6BB Electric range
General Electric ZET958BF7BB Electric range
General Electric ZET958BM1BB ELECTRIC WALL OVEN
General Electric ZET958BM2BB ELECTRIC OVEN
General Electric ZET958SF1SS Electric range
General Electric ZET958SF2SS Electric range
General Electric ZET958SF3SS Electric range
General Electric ZET958SF4SS Electric range
General Electric ZET958SF5SS Electric range
General Electric ZET958SF6SS Electric range
General Electric ZET958SF7SS Electric range
General Electric ZET958SM1SS BUILT IN OVEN
General Electric ZET958SM2SS BUILT IN OVEN
General Electric ZET958WF1WW Electric range
General Electric ZET958WF2WW Electric range
General Electric ZET958WF3WW Electric range
General Electric ZET958WF4WW Electric range
General Electric ZET958WF5WW Electric range
General Electric ZET958WF6WW Electric range
General Electric ZET958WF7WW Electric range
General Electric ZET958WM1WW ELECTRIC WALL OVEN
General Electric ZEU304ABG Electric range
General Electric ZEU304B1WG Electric range
General Electric ZEU30RBF1BB Electric range
General Electric ZEU30RBF2BB Electric range
General Electric ZEU30RSF1SS Electric range
General Electric ZEU30RSF2SS Electric range
General Electric ZEU30RWF1WW Electric range
General Electric ZEU30RWF2WW Electric range
General Electric ZEU365ABG Electric range
General Electric ZEU365B1WG Electric range
General Electric ZEU36KBK1BB Electric range
General Electric ZEU36KBK2BB ELECTRIC COOKTOP
General Electric ZEU36KSK1SS Electric range
General Electric ZEU36KSK2SS ELECTRIC COOKTOP
General Electric ZEU36KSK3SS ELECTRIC COOKTOP
General Electric ZEU36KWK1WW Electric range
General Electric ZEU36KWK2WW ELECTRIC COOKTOP
General Electric ZEU36RBF1BB Electric range
General Electric ZEU36RBF2BB Electric range
General Electric ZEU36RSF1SS Electric range
General Electric ZEU36RSF2SS Electric range
General Electric ZEU36RWF1WW Electric range
General Electric ZEU36RWF2WW Electric range
General Electric ZEU36WMRA2BG Electric range
General Electric ZEU36WMRABG Electric range
General Electric ZEU36WMRB1WG Electric range
General Electric ZEU632L1 Electric range
General Electric ZEU632P1 Electric range
General Electric ZEU632P1T COOKTOP
General Electric ZEU633L1 Electric range
General Electric ZEU633P1 Electric range
General Electric ZEU633P1T COOKTOP
General Electric ZEU634L1 Electric range
General Electric ZEU634P1 Electric range
General Electric ZEU668A1BB Electric range
General Electric ZEU668A2BB Electric range
General Electric ZEU668T1BB Electric range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Electronic panel goes dark after oven preheats jmocchi Oven Repair (including Ranges and Cooktops) 0 07-21-2012 11:35 AM
Kenmore Gas Stove Control Panel Dark David Cruise Oven Repair (including Ranges and Cooktops) 0 03-06-2011 09:41 AM
Oven control assy went dark Richardwal Oven Repair (including Ranges and Cooktops) 2 05-13-2009 12:35 PM
GE Monogram Control Panel Handymanman Dishwasher Repair 3 11-13-2008 10:47 AM
oven control dark Earlandtrudyg Oven Repair (including Ranges and Cooktops) 0 08-29-2007 03:11 PM
