Kenmore Gas Oven Low Burner & Oven Flames.
I have a Kenmore gas oven, Model # 790.78783407 that I bought used for a rental home. I am using
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Kenmore Gas Oven Low Burner & Oven Flames.
  #1 (permalink)
Old 01-30-2014, 06:15 AM
Junior Member
Tabby is on a distinguished road
Default Kenmore Gas Oven Low Burner & Oven Flames.
Model Number: 790.78783407   Brand: Kenmore   Age: 5 - 10 years
I have a Kenmore gas oven, Model # 790.78783407 that I bought used for a rental home. I am using Natural Gas. The flame output on the top burners are low and the oven takes nearly 20 - 25 minutes to reach 350 degrees. First thing that came to mind was the gas supply pressure being too low, so I had the local gas company come out and they checked both the outside gas meter and then came in the house and put a meter on the line by the furnace and had me turn on my 30,000 btu gas fireplace and gas water tank. The pressure remained consistent and they said there are no issues with the pressure.
So I then took a look at the Pressure Regulator to see if was switched to LP. It didn't appear to be, but as a test, I reversed the plug so that it was now set for LP. The burner output for both the oven and top burners were no different? I turned on the broiler and it ignited correctly, but the flames were very weak, about 1/4 inch in length. So I switched every thing back to Natural Gas and the flames were still the same as expected.
I read that if the Pressure Regulator bypass/service switch is turned off, that the oven will not get gas at all and not light. So I flipped the switch to OFF or Service and to my surprise, the oven would still light up with the same low output flame!!! While the broiler burner was on, I would flip the switch on the Pressure regulator ON and OFF and back ON every 10 seconds. The oven flame remained on with no difference in flame output no matter what the switch was set to. I then turned the top surface burners on and still no difference in flame output. So it appears that I get the same level of gas to the oven no matter what and it doesn't matter how many burners are on, the flame output levels remain the same.
So my theory now is that the Pressure regulator is bad and only allow a certain amount of gas into the oven no matter what, or that there is gas restriction in the gas pipe just before entering the oven. Wish the utility service person could have checked the output right at the oven, but they didn't and it was a no cost service call so I can't complain.
Any thoughts on the Pressure regulator being the culprit? When turning off the gas using the service switch on the Pressure regulator, should this turn off all gas to the oven or just reduce it. It appears this switch only affects the oven and not the top burners since it is where the gas exits to the oven. Why have a switch at all if it doesn't cut off all of the gas?
Thank you,
Related Models
Kenmore 79015011400 ELECTRIC RANGE
Kenmore 79015011401 ELECTRIC RANGE
Kenmore 79015021400 ELECTRIC RANGE
Kenmore 79015021401 ELECTRIC RANGE
Kenmore 79015031400 ELECTRIC RANGE
Kenmore 79015031401 ELECTRIC RANGE
Kenmore 79015032500 ELECTRIC RANGE
Kenmore 79015051401 GAS RANGE
Kenmore 79030172400 GAS WALLOVEN
Kenmore 79030172401 GAS WALLOVEN
Kenmore 79030179400 GAS WALLOVEN
Kenmore 79030179401 GAS WALLOVEN
Kenmore 79030472400 GAS WALLOVEN
Kenmore 79030472401 GAS WALLOVEN
Kenmore 79030472402 GAS WALLOVEN
Kenmore 79030473400 GAS WALLOVEN
Kenmore 79030473401 GAS WALLOVEN
Kenmore 79030473402 GAS WALLOVEN
Kenmore 79030473403 GAS WALLOVEN
Kenmore 79030474400 GAS WALLOVEN
Kenmore 79030474401 GAS WALLOVEN
Kenmore 79030474402 GAS WALLOVEN
Kenmore 79030479400 GAS WALLOVEN
Kenmore 79030479401 GAS WALLOVEN
Kenmore 79030479402 GAS WALLOVEN
Kenmore 79030503600 GAS COOKTOP
Kenmore 79030503601 GAS COOKTOP
Kenmore 79030522800 WALL OVEN
Kenmore 79030522801 WALL OVEN
Kenmore 79030529800 WALL OVEN
Kenmore 79030529801 WALL OVEN
Kenmore 79030552800 GAS WALLOVEN
Kenmore 79030552802 GAS WALLOVEN
Kenmore 79030553800 GAS WALLOVEN
Kenmore 79030553802 GAS WALLOVEN
Kenmore 79030554800 GAS WALLOVEN
Kenmore 79030554802 GAS WALLOVEN
Kenmore 79030559800 GAS WALLOVEN
Kenmore 79030559802 GAS WALLOVEN
Kenmore 79031003600 GAS COOKTOP
Kenmore 79031013600 GAS COOKTOP
Kenmore 79031023700 SEARS PRO/COOKTOP
Kenmore 79031023701 COOKTOP
Kenmore 79031032800 GAS RANGE
Kenmore 79031032801 GAS RANGE
Kenmore 79031032802 GAS RANGE
Kenmore 79031032804 GAS RANGE
Kenmore 79031033800 GAS RANGE
Kenmore 79031033801 GAS RANGE
Kenmore 79031033802 GAS RANGE
Kenmore 79031033803 GAS RANGE
Kenmore 79031033804 GAS RANGE
Kenmore 79031034800 GAS RANGE
Kenmore 79031034801 GAS RANGE
Kenmore 79031034802 GAS RANGE
Kenmore 79031039800 GAS RANGE
Kenmore 79031039801 GAS RANGE
Kenmore 79031039802 GAS RANGE
Kenmore 79031039804 GAS RANGE
Kenmore 79031042800 GAS RANGE
Kenmore 79031042801 GAS RANGE
Kenmore 79031042802 GAS RANGE
Kenmore 79031042803 GAS RANGE
Kenmore 79031042805 GAS RANGE
Kenmore 79031043800 GAS RANGE
Kenmore 79031043801 GAS RANGE
Kenmore 79031043802 GAS RANGE
Kenmore 79031043803 GAS RANGE
Kenmore 79031043805 GAS RANGE
Kenmore 79031049800 GAS RANGE
Kenmore 79031049801 GAS RANGE
Kenmore 79031049802 GAS RANGE
Kenmore 79031049803 GAS RANGE
Kenmore 79031049805 GAS RANGE
Kenmore 79031053000 GAS RANGE
Kenmore 79031062100 GAS RANGE
Kenmore 79031063100 GAS RANGE
Kenmore 79031069100 GAS RANGE
Kenmore 79031073100 GAS RANGE
Kenmore 79032092400 GAS COOKTOP
Kenmore 79032092401 GAS COOKTOP
Kenmore 79032092402 GAS COOKTOP
Kenmore 79032094400 GAS COOKTOP
Kenmore 79032094401 GAS COOKTOP
Kenmore 79032094402 GAS COOKTOP
Kenmore 79032099400 GAS COOKTOP
Kenmore 79032099401 GAS COOKTOP
Kenmore 79032099402 GAS COOKTOP
Kenmore 79032232400 GAS COOKTOP
Kenmore 79032232401 GAS COOKTOP
Kenmore 79032233400 GAS COOKTOP
Kenmore 79032233401 GAS COOKTOP
Kenmore 79032234400 GAS COOKTOP
Kenmore 79032234401 GAS COOKTOP
Kenmore 79032239400 GAS COOKTOP
Kenmore 79032239401 GAS COOKTOP
Kenmore 79032242400 GAS COOKTOP
Kenmore 79032242401 GAS COOKTOP
Kenmore 79032243400 GAS COOKTOP
Kenmore 79032243401 GAS COOKTOP
Kenmore 79032244400 GAS COOKTOP
Kenmore 79032244401 GAS COOKTOP
Kenmore 79032249400 GAS COOKTOP
Kenmore 79032249401 GAS COOKTOP
Kenmore 79032302000 GAS COOKTOP
Kenmore 79032303000 GAS COOKTOP
Kenmore 79032309000 GAS COOKTOP
Kenmore 79032312000 GAS COOKTOP
Kenmore 79032313000 GAS COOKTOP
Kenmore 79032319000 GAS COOKTOP
Kenmore 79032323000 GAS COOKTOP
Kenmore 79032329000 GAS COOKTOP
Kenmore 79032333000 GAS COOKTOP
Kenmore 79032339000 GAS COOKTOP
Kenmore 79032353000 COOKTOP
Kenmore 79032392400 GAS COOKTOP
Kenmore 79032392401 GAS COOKTOP
Kenmore 79032393700 GAS COOKTOP
Kenmore 79032394400 GAS COOKTOP
Kenmore 79032394401 GAS COOKTOP
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Excessive Oven Burner Flames lourothbart Oven Repair (including Ranges and Cooktops) 0 07-21-2012 04:03 PM
Flames too big in Kenmore propane oven tdarwin Oven Repair (including Ranges and Cooktops) 0 12-24-2010 05:31 PM
Gas Oven Flames too big LP gas howabusa Oven Repair (including Ranges and Cooktops) 0 12-05-2010 08:05 AM
oven flames shoot into oven compartment Susan Fey Oven Repair (including Ranges and Cooktops) 0 05-03-2009 12:03 PM
the flames into the oven go on and off victor borcea Oven Repair (including Ranges and Cooktops) 1 04-02-2008 05:36 AM
