Discuss
Yellow flames ? Air fuel problem
 in
I have a Ge Glass top convention oven stove #JGS968SH3SS . The flames go from larger and yellow to regular
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Yellow flames ? Air fuel problem
  #1 (permalink)
Old 01-29-2014, 02:09 PM
Junior Member
rm3350 is on a distinguished road
Default Yellow flames ? Air fuel problem
Model Number: JGS968SH3SS   Brand: GE   Age: 5 - 10 years
The flames go from larger and yellow to regular and make pots black soot .
I was told its the orfices and burner tubes need to be changed . The orfices are clear ,but I see carbon .
I really need a good repair schematic of exploded view on assembly ?
Also one of the burners need to be replaced ,and they are no longer made can I use a different size burner ?
Also do the seals stay intacted when taking off the glass top, or should I order those as well .
As far as the oven I need to check it I think those flames are yellow at times also . The only part that the flames are good on the broiler which we never used at all . Nice and blue tight flames .
any help would be great so I can get the parts needed and move forward .
Related Models
General Electric JGS968SH3SS Gas range
General Electric JGS968SH4SS Gas range
General Electric JGS968SH5SS Gas range
General Electric JGS968SH6SS Gas range
General Electric JGS968TEK1WW Gas range
General Electric JGS968TEK2WW Gas range
General Electric JGS968TEK3WW Gas range
General Electric JGS968TEK4WW GAS RANGE
General Electric JGS968TH1WW Gas range
General Electric JGS968TH2WW Gas range
General Electric JGS968TH3WW Gas range
General Electric JGS968TH4WW Gas range
General Electric JGS968TH5WW Gas range
General Electric JGS968TH6WW Gas range
Jenn-Air JGS9900BDB RANGE- S/C S/I DDRAFT GAS
Maytag JGS9900BDB15 30" SLIDE-IN DOWNDRAFT RANGE GAS ON GLASS
Jenn-Air JGS9900BDF RANGE- S/C S/I DDRAFT GAS
Maytag JGS9900BDF15 30" SLIDE-IN DOWNDRAFT RANGE GAS ON GLASS
Jenn-Air JGS9900BDS RANGE- S/C S/I DDRAFT GAS
Maytag JGS9900BDS15 30" SLIDE-IN DOWNDRAFT RANGE GAS ON GLASS
Maytag JGS9900BDS16 30" SLIDE-IN DOWNDRAFT RANGE GAS ON GLASS
Maytag JGS9900CDB00 30" SLIDE-IN DOWNDRAFT RANGE GAS ON GLASS
Maytag JGS9900CDF00 30" SLIDE-IN DOWNDRAFT RANGE GAS ON GLASS
Maytag JGS9900CDR00 30" SLIDE-IN DOWNDRAFT RANGE GAS ON GLASS
Maytag JGS9900CDS00 30" SLIDE-IN DOWNDRAFT RANGE GAS ON GLASS
Maytag JGS9900CDS01 30" SLIDE IN GAS ON GLASS DOWNDRAFT RANGE
Jenn-Air JGS9900CDS02 30" SLIDE-IN GAS ON GLASS DOWNDRAFT RANGE
General Electric JGSC07GEJ1 Electric range
General Electric JGSC07GEJ2 Gas range
General Electric JGSC08GEK1 Electric range
General Electric JGSC08GEK3 Electric range
General Electric JGSC12GEP1 Gas range
General Electric JGSC12GER1BG Gas range
General Electric JGSC12GET1BG Gas range
General Electric JGSC12GEV1BG Gas range
General Electric JGSP10GEK1 Electric range
General Electric JGSP10GEK2 Gas range
General Electric JGSP10GEK3 Electric range
General Electric JGSP20GEP1 Electric range
General Electric JGSP20GEP2 Gas range
General Electric JGSP20GER1BG Gas range
General Electric JGSP20GER2BG Gas range
General Electric JGSP20GER3BG Gas range
General Electric JGSP20GET1BB Gas range
General Electric JGSP21GEP1 Gas range
General Electric JGSP21GEP2 Gas range
General Electric JGSP21GER1WH Gas range
General Electric JGSP21GER2WH Gas range
General Electric JGSP21GER3WH Gas range
General Electric JGSP21WET1WW Gas range
General Electric JGSP22GEV1BB Gas range
General Electric JGSP22GEV3BB Gas range
General Electric JGSP23BEW1BB Gas range
General Electric JGSP23BEY1BB Gas range
General Electric JGSP23BEY2BB Gas range
General Electric JGSP23BEY3BB Gas range
General Electric JGSP23BEY4BB Gas range
General Electric JGSP23BEY5BB Gas range
General Electric JGSP23CEY1CC Gas range
General Electric JGSP23WEV1WW Gas range
General Electric JGSP23WEV2WW Gas range
General Electric JGSP23WEV5WW Gas range
General Electric JGSP23WEV6WW Gas range
General Electric JGSP23WEW1WW Gas range
General Electric JGSP23WEY1WW Gas range
General Electric JGSP23WEY2WW Gas range
General Electric JGSP23WEY3WW Gas range
General Electric JGSP23WEY5WW Gas range
General Electric JGSP23WEY6WW Gas range
General Electric JGSP23WEY7WW Gas range
General Electric JGSP28BEK1BB Gas range
General Electric JGSP28BEK2BB Gas range
General Electric JGSP28BEK3BB Gas range
General Electric JGSP28BEK4BB Gas range
General Electric JGSP28BEK5BB GAS RANGE
General Electric JGSP28CEK1CC Gas range
General Electric JGSP28CEK2CC Gas range
General Electric JGSP28CEK3CC Gas range
General Electric JGSP28CEK4CC Gas range
General Electric JGSP28CEK5CC GAS RANGE
General Electric JGSP28DEN1BB GAS RANGE
General Electric JGSP28DEN1CC GAS RANGE
General Electric JGSP28DEN1WW GAS RANGE
General Electric JGSP28DEN2BB GAS RANGE
General Electric JGSP28DEN2CC GAS RANGE
General Electric JGSP28DEN2WW GAS RANGE
General Electric JGSP28DEN3BB GAS RANGE
General Electric JGSP28DEN3CC GAS RANGE
General Electric JGSP28DEN3WW GAS RANGE
General Electric JGSP28SEK1SS Gas range
General Electric JGSP28SEK2SS Gas range
General Electric JGSP28SEK3SS Gas range
General Electric JGSP28SEK4SS Gas range
General Electric JGSP28SEK5SS GAS RANGE
General Electric JGSP28SEN1SS GAS RANGE
General Electric JGSP28SEN2SS GAS RANGE
General Electric JGSP28SEN3SS GAS RANGE
General Electric JGSP28SEN4SS GAS RANGE
General Electric JGSP28WEK1WW Gas range
General Electric JGSP28WEK2WW Gas range
General Electric JGSP28WEK3WW Gas range
General Electric JGSP28WEK4WW Gas range
General Electric JGSP28WEK5WW GAS RANGE
General Electric JGSP30GEP1 Electric range
General Electric JGSP30GEP2 SLIDE-IN RANGE, GAS
General Electric JGSP30GEP4BG Gas range
General Electric JGSP30GEP5BG Electric range
General Electric JGSP30GER1BG Gas range
General Electric JGSP30GER2BG Gas range
General Electric JGSP30GER3BG Gas range
General Electric JGSP30GET1BB Gas range
General Electric JGSP31GEP1 Gas range
General Electric JGSP31GEP4 Gas range
General Electric JGSP31GEP5WG Gas range
General Electric JGSP31GEP6WG Electric range
General Electric JGSP31GER1WG Gas range
General Electric JGSP31GER2WG Gas range
General Electric JGSP31GER3WG Gas range
General Electric JGSP31WET1WW Gas range
General Electric JGSP32GEV1BB Gas range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Yellow flames all 4 burners dave27 Oven Repair (including Ranges and Cooktops) 0 01-03-2014 12:44 PM
Older Maytag yellow flames mdhomeowner Oven Repair (including Ranges and Cooktops) 3 02-12-2012 05:29 PM
Yellow flames on four burners and broiler Nel1956 Oven Repair (including Ranges and Cooktops) 5 03-01-2011 07:54 AM
Yellow flames on burners dfehl Oven Repair (including Ranges and Cooktops) 1 09-30-2009 07:14 PM
Flames yellow on gas cooktop olean Oven Repair (including Ranges and Cooktops) 0 06-01-2009 10:31 AM
