Discuss
need to know how to connect the wires
 in
Hello all, I have an older Magic Chef range, and I used the self cleaning feature and after it was
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » need to know how to connect the wires
  #1 (permalink)
Old 01-28-2014, 02:50 PM
Junior Member
WVLADY is on a distinguished road
Smile need to know how to connect the wires
Brand: Magic Chef   Age: More than 10 years
Hello all, I have an older Magic Chef range, and I used the self cleaning feature and after it was done, my oven would not heat up above 150 degrees. What I have found is that the element (or the big wire thing that heats up in the bottom of the oven is not connected to the wires on the back of the range. I don't know how to reconnect the wires....can someone help me. Thanks much.
  #2 (permalink)
Old 01-29-2014, 03:15 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Sorry but I do not understand the problem.
The female connectors on the wires just push on to the male connectors on the element.
Be sure that the unit is unplugged when working on it.
You may have to remove the rear cover of the unit to do this.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
How to properly connect wires to capacitor? G C Washer Repair 4 08-17-2012 02:24 PM
connect wires to new terminal block stant Dryer Repair 2 06-07-2010 01:33 PM
Dryer Wires Where Does The Wires Go On The Timer 0425NENE Dryer Repair 1 11-18-2009 05:36 PM
Cannot connect my new electrode Kelehan Oven Repair (including Ranges and Cooktops) 1 11-07-2008 07:59 PM
How do I connect wires to turntable motor? ltml82 Microwave Repair 1 02-20-2008 04:37 PM
