Discuss
Jenn-Air Success Story
 in
Folks, After three years of intermittent and perplexing behavior from the Jenn-air down-draft range that came with my house, I
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Jenn-Air Success Story
  #1 (permalink)
Old 01-21-2014, 01:16 PM
Junior Member
TigerDriver is on a distinguished road
Thumbs up Jenn-Air Success Story
Model Number: MODEL: sve47600w   Brand: Jenn-Air   Age: More than 10 years
Folks,
After three years of intermittent and perplexing behavior from the Jenn-air down-draft range that came with my house, I finally broke down and installed a new relay board and oven temperature sensor. Not only are all the problems gone, I now actually see how the range is supposed to work.
1. Oven now holds temperature and is accurate +/-5%.
2. Previously, display would indicate set temp, but actual temp would be far lower.
3. Oven fan runs at lower speed and is almost silent
4. Oven fan shuts off immediately when oven cools down; before it would run for hours.
5. Alert bell now works
I'm a retired electrical/electronics engineer and undertake such projects fearlessly. It's difficult to judge whether an ordinary "handy" person should undertake this project. Some of the wiring to the relay board is via multi-wire J-connectors that cannot be installed incorrectly--so these are a snap. However, the power-controlling wires attach with old-fashioned spade connectors, which sometimes require an extra-ordinary amount of force to remove and re-install. I'm accustomed to working with such connectors, but do-it-yourselfers might be disconcerted by the hefty force required to separate and reunite the male and female halves.
Before beginning, I recommend that you take several photos of the board AND make a crude drawing that shows where each wire plugs into the board.
Because my oven was not holding the displayed temperature, I also replaced the temperature sensor in the oven. It's a 10-minute task and the new part seems better-made than the original.
So in one swoop I've eliminated two negatives in my life: a stove that doesn't work well and a wife who nags me incessantly to fix it.
Good luck and thanks for the folks at Appliance Parts Pros.
Joe C.
Related Models
Whirlpool MODEL_PBK0190
Magic Chef MODW1A MWAVE- MOUNTED OVER RANGE/WO
Magic Chef MODW1V MWAVE- MOUNTED OVER RANGE/WO
Amana MP1.A COMMERCIAL MICROWAVES
Amana MP1.B COMMERCIAL MICROWAVES
Amana MPD218-02 MWAVE - FAMILY SIZE (60 HZ)
Frigidaire MPF200PBDA Frg(v2) / Gas Range
Frigidaire MPF200PBWA Frg(v1) / Gas Range
Frigidaire MPF240GSA GAS RANGE
Frigidaire MPF300BPDA Gib(v9) / Gas Range
Frigidaire MPF300PBDA Frg(v1) / Gas Range
Frigidaire MPF300PBDB Wwh(v1) / Gas Range
Frigidaire MPF300PBDC Frg(v1) / Gas Range
Frigidaire MPF300PBDD Frg(v1) / Gas Range
Frigidaire MPF300PBDE Frg(v1) / Gas Range
Frigidaire MPF300PBDF Frg(v1) / Gas Range
Frigidaire MPF300PBWA Frg(v2) / Gas Range
Frigidaire MPF300PBWB Wwh(v2) / Gas Range
Frigidaire MPF300PBWC Frg(v2) / Gas Range
Frigidaire MPF300PBWD Frg(v2) / Gas Range
Frigidaire MPF300PBWE Frg(v2) / Gas Range
Frigidaire MPF300PBWF Frg(v2) / Gas Range
Frigidaire MPF300PXWA Frg(v0) / Gas Range
Frigidaire MPF300PXWB Frg(v3) / Gas Range
Frigidaire MPF300PXWC Frg(v0) / Gas Range
Frigidaire MPF300PXWG Universal/gas Range
Frigidaire MPF300PXWH Universal/gas Range
Frigidaire MPF300PXWJ Universal/gas Range
Frigidaire MPF303PGDA Frg(v3) / Gas Range
Frigidaire MPF303PGDD Frg(v5) / Gas Range
Frigidaire MPF303PGDF Universal/gas Range
Frigidaire MPF303PGDG Universal/gas Range
Frigidaire MPF303PGDH Universal/gas Range
Frigidaire MPF303PGWA Frg(v4) / Gas Range
Frigidaire MPF303PGWC Frg(v6) / Gas Range
Frigidaire MPF303PGWD Frg(v7) / Gas Range
Frigidaire MPF303PGWF Universal/gas Range
Frigidaire MPF303PGWG Universal/gas Range
Frigidaire MPF303PGWH Universal/gas Range
Frigidaire MPF311PCDA Tap(v1) / Gas Range
Frigidaire MPF311PCWA Tap(v2) / Gas Range
Frigidaire MPF311PCWB Frg(v0) / Gas Range
Frigidaire MPF311PCWC Frg(v1) / Gas Range
Frigidaire MPF311PCWD Frg(v0) / Gas Range
Frigidaire MPF311PGWA Frg(v3) / Gas Range
Frigidaire MPF311PGWC Frg(v3) / Gas Range
Frigidaire MPF311PGWD Frg(v3) / Gas Range
Frigidaire MPF311PGWE Universal/gas Range
Frigidaire MPF311SBDA Frg(v3) / Gas Range
Frigidaire MPF311SBDB Frg(v1) / Gas Range
Frigidaire MPF311SBDC Frg(v2) / Gas Range
Frigidaire MPF311SBDD Frg(v1) / Gas Range
Frigidaire MPF311SBWA Frg(v4) / Gas Range
Frigidaire MPF311SBWB Frg(v2) / Gas Range
Frigidaire MPF311SBWC Frg(v3) / Gas Range
Frigidaire MPF311SBWD Frg(v2) / Gas Range
Frigidaire MPF311SGDA Frg(v4) / Gas Range
Frigidaire MPF311SGDC Frg(v4) / Gas Range
Frigidaire MPF311SGDD Frg(v4) / Gas Range
Frigidaire MPF311SGDE Universal/gas Range
Frigidaire MPF311SGWA Frg(v5) / Gas Range
Frigidaire MPF311SGWC Frg(v5) / Gas Range
Frigidaire MPF311SGWD Frg(v5) / Gas Range
Frigidaire MPF311SGWE Universal/gas Range
Frigidaire MPF500PBDA Frg(v4) / Gas Range
Frigidaire MPF500PBDB Frg(v1) / Gas Range
Frigidaire MPF500PBWA Frg(v3) / Gas Range
Frigidaire MPF500PBWB Frg(v2) / Gas Range
Amana MPP227 MWAVE- CNTRTP / STAND ALONE
Amana MPP228 MWAVE- CNTRTP / STAND ALONE
Amana MPP228100L MWAVE - FAMILY SIZE (60 HZ)
Amana MPR215 MWAVE- CNTRTP / STAND ALONE
Amana MPR21510 MWAVE- MOUNTED OVER RANGE/WO
Amana MPR217 MWAVE- CNTRTP / STAND ALONE
Amana MPR219 MWAVE- CNTRTP / STAND ALONE
Amana MPS218-10 RANGE- S/C S/I DDRAFT GAS
Amana MPS218-10 MWAVE- CNTRTP / STAND ALONE
Amana MPS219-10 RANGE- S/C S/I DDRAFT GAS
Amana MPS219-10 MWAVE- CNTRTP / STAND ALONE
Amana MPS225-10 MWAVE - FAMILY SIZE (60 HZ)
Amana MPS22510 MWAVE - FAMILY SIZE (60 HZ)
Amana MPS229-10 MWAVE - FAMILY SIZE (60 HZ)
Amana MPS22910 MWAVE - FAMILY SIZE (60 HZ)
Maytag MQC1557AEW FREEZER- VERTICAL
Maytag MQC1557BEW FREEZER- CHEST
Maytag MQC2257AEW FREEZER- CHEST
Maytag MQC2257BEW FREEZER- CHEST
Maytag MQU1554AEW FREEZER- VERTICAL
Maytag MQU1556AEW FREEZER- VERTICAL
Maytag MQU1654BEW FREEZER- VERTICAL
Maytag MQU1656BEW FREEZER- VERTICAL
Maytag MQU2056ARW FREEZER- VERTICAL
Maytag MQU2056BRW FREEZER- VERTICAL
Maytag MQU2056BRW03 VERTICAL FREEZER
Maytag MQU2057AEW FREEZER- VERTICAL
Maytag MQU2057BEW FREEZER- VERTICAL
Amana MR-1 RANGE- S/C S/I DDRAFT GAS
Amana MR-1W MWAVE - FAMILY SIZE (60 HZ)
Amana MR-2 RANGE- S/C S/I DDRAFT GAS
Amana MR-3 MWAVE - FAMILY SIZE (60 HZ)
 MR1031CWC MWAVE- CNTRTP / STAND ALONE
 MR1031UWC MWAVE- CNTRTP / STAND ALONE
 MR1031WB MWAVE- CNTRTP / STAND ALONE
 MR1032BB MWAVE- CNTRTP / STAND ALONE
 MR1032CBC MWAVE- CNTRTP / STAND ALONE
 MR1032UBC MWAVE- CNTRTP / STAND ALONE
 MR1033SB MWAVE- CNTRTP / STAND ALONE
 MR1034CBD MWAVE- CNTRTP / STAND ALONE
 MR1034CWD MWAVE- CNTRTP / STAND ALONE
 MR1034UBD MWAVE- CNTRTP / STAND ALONE
 MR1034UWD MWAVE- CNTRTP / STAND ALONE
 MR1351WB MWAVE- CNTRTP / STAND ALONE
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thanksgiving success story - F1-2 code mtehan Oven Repair (including Ranges and Cooktops) 1 03-10-2016 10:22 AM
Success story: washer had no power fumblinginthedark Washer Repair 2 11-01-2013 07:35 AM
Another Maytag Oven F1 story jdptsax Oven Repair (including Ranges and Cooktops) 2 03-01-2009 08:59 AM
