Discuss
30" Kitchen Aid Sealed Burner Gas Range Not Lighting (No Spark w/Knob)
 in
I do not have any spark when I turn the knobs to the light position. (No sound and it will
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » 30" Kitchen Aid Sealed Burner Gas Range Not Lighting (No Spark w/Knob)
  #1 (permalink)
Old 01-19-2014, 03:07 PM
Junior Member
DizzyDean is on a distinguished road
Default 30" Kitchen Aid Sealed Burner Gas Range Not Lighting (No Spark w/Knob)
Model Number: KGST300FWH0   Brand: Kitchen Aid   Age: More than 10 years
I do not have any spark when I turn the knobs to the light position. (No sound and it will not light the gas.)
Sporadically, I hear a faint clicking sound when everything is turned off. This sound comes from the front left burner. If I turn any of the knobs on during the sound, there is still no ignition.
I can turn gas on and light the burners manually and they work.
I can feel the end of the ignition tip with my finger and feel a little shock.
I have cleaned all the tips and made sure all knobs are dry, as well. There has never been a spill or water on the range. I checked to make sure there was not a pinched wire, either.
My next move is to replace the spark module, but I want to make sure that is the is the problem.
The oven works fine.
Any help from someone with experience would be appreciated.
It was new in 1997 and this is the only problem I've ever had with it. It is the slide-in range, too, if that matters.
Thank you very much!
Related Models
Whirlpool KGST300FWH0 30" SLIDE IN GAS RANGE
Whirlpool KGST300FWH1 30" SLIDE-IN GAS RANGE
Whirlpool KGST300FWH2 30" SLIDE-IN GAS RANGE
Whirlpool KGST300HBL6 GAS RANGE
Whirlpool KGST300HBL8 SLIDE IN GAS RANGE
Whirlpool KGST300HBL9 GAS SLIDE IN RANGE
Whirlpool KGST300HBT0 GAS RANGE
Whirlpool KGST300HBT2 GAS RANGE
Whirlpool KGST300HBT3 GAS RANGE
Whirlpool KGST300HBT4 GAS RANGE
Whirlpool KGST300HBT5 GAS RANGE
Whirlpool KGST300HBT6 GAS RANGE
Whirlpool KGST300HBT8 SLIDE IN GAS RANGE
Whirlpool KGST300HBT9 GAS SLIDE IN RANGE
Whirlpool KGST300HWH0 GAS RANGE
Whirlpool KGST300HWH2 GAS RANGE
Whirlpool KGST300HWH3 GAS RANGE
Whirlpool KGST300HWH4 GAS RANGE
Whirlpool KGST300HWH5 GAS RANGE
Whirlpool KGST300HWH6 GAS RANGE
Whirlpool KGST300HWH8 SLIDE IN GAS RANGE
Whirlpool KGST300HWH9 GAS SLIDE IN RANGE
Whirlpool KGST307BAL0 30" GAS SLIDE-IN RANGE
Whirlpool KGST307BAL1 30" SLIDE-IN GAS RANGE
Whirlpool KGST307BAL2 30" SLIDE-IN GAS RANGE
Whirlpool KGST307BBL0 30" GAS SLIDE-IN RANGE
Whirlpool KGST307BBL1 30" SLIDE-IN GAS RANGE
Whirlpool KGST307BBL2 30" SLIDE-IN GAS RANGE
Whirlpool KGST307BWH0 30" GAS SLIDE-IN RANGE
Whirlpool KGST307BWH1 30" SLIDE-IN GAS RANGE
Whirlpool KGST307BWH2 30" SLIDE-IN GAS RANGE
Whirlpool KGST307FAL0 30" SLIDE IN CONV. OVEN
Whirlpool KGST307FAL1 30" SLIDE-IN RANGE
Whirlpool KGST307FBL0 30" SLIDE IN CONV. OVEN
Whirlpool KGST307FBL1 30" SLIDE-IN RANGE
Whirlpool KGST307FWH0 30" SLIDE IN CONV. OVEN
Whirlpool KGST307FWH1 30" SLIDE-IN RANGE
Whirlpool KGST307GAL0 30" SLIDE-IN COVECTION RANGE
Whirlpool KGST307GBL0 30" SLIDE-IN COVECTION RANGE
Whirlpool KGST307GBS0 30" SLIDE-IN RANGE
Whirlpool KGST307GBT0 30" SLIDE-IN COVECTION RANGE
Whirlpool KGST307GWH0 30" SLIDE-IN RANGE
Whirlpool KGST307HBL0 GAS SLIDE-IN RANGE
Whirlpool KGST307HBL2 GAS SLIDE IN RANGE
Whirlpool KGST307HBL3 GAS SLIDE-IN RANGE
Whirlpool KGST307HBL4 GAS SLIDE-IN RANGE
Whirlpool KGST307HBL5 SLIDE-IN RANGE,GAS
Whirlpool KGST307HBL6 RANGE
Whirlpool KGST307HBL8 30" SLIDE IN GAS RANGE
Whirlpool KGST307HBL9 GAS SLIDE IN RANGE
Whirlpool KGST307HBS0 GAS SLIDE-IN RANGE
Whirlpool KGST307HBS1 GAS RANGE
Whirlpool KGST307HBS2 GAS SLIDE IN RANGE
Whirlpool KGST307HBS3 GAS SLIDE-IN RANGE
Whirlpool KGST307HBS4 GAS SLIDE-IN RANGE
Whirlpool KGST307HBS5 SLIDE-IN RANGE, GAS
Whirlpool KGST307HBS6 RANGE
Whirlpool KGST307HBS8 30" SLIDE IN GAS RANGE
Whirlpool KGST307HBS9 GAS SLIDE IN RANGE
Whirlpool KGST307HBT0 GAS SLIDE-IN RANGE
Whirlpool KGST307HBT2 GAS SLIDE IN RANGE
Whirlpool KGST307HBT3 GAS SLIDE-IN RANGE
Whirlpool KGST307HBT4 GAS SLIDE-IN RANGE
Whirlpool KGST307HBT5 SLIDE-IN RANGE, GAS
Whirlpool KGST307HBT6 RANGE
Whirlpool KGST307HBT8 30" SLIDE IN GAS RANGE
Whirlpool KGST307HBT9 GAS SLIDE IN RANGE
Whirlpool KGST307HWH0 GAS SLIDE-IN RANGE
Whirlpool KGST307HWH2 GAS SLIDE IN RANGE
Whirlpool KGST307HWH3 GAS SLIDE-IN RANGE
Whirlpool KGST307HWH4 GAS SLIDE-IN RANGE
Whirlpool KGST307HWH5 SLIDE-IN RANGE, GAS
Whirlpool KGST307HWH6 RANGE
Whirlpool KGST307HWH8 30" SLIDE IN GAS RANGE
Whirlpool KGST307HWH9 GAS SLIDE IN RANGE
Amana KGT-591 RANGE- S/C S/I DDRAFT GAS
Amana KGT-593 RANGE- S/C S/I DDRAFT GAS
Amana KGT-693 RANGE- S/C S/I DDRAFT GAS
Amana KGT341 SURFACE UNIT- GAS
KitchenAid KGTC366EAL0 36" GAS GLASS BURNER COOKTOP
Admiral KGU5700BS REF - SXS
Admiral KGU57990KD REF - SXS/I&W
Admiral KGU5950BS REF - SXS
Admiral KGU5955BS REF - SXS
Admiral KGU6465BS REF - SXS/I&W
Admiral KGU6650 REF - SXS/I&W
Admiral KGU6651 REF - SXS/I&W
Admiral KGU6655 REF - SXS/I&W
Admiral KGU66920 REF - SXS/I&W
Admiral KGU6695 REF - SXS/I&W
Admiral KGU66990 REF - SXS/I&W
Admiral KGU6700BS REF - SXS/I&W
Admiral KGU6940BS REF - SXS/I&W
Admiral KGU6945BS REF - SXS/I&W
Whirlpool KGYE550VWH0 Residential Dryer
Whirlpool KGYE560WAL0
Whirlpool KGYE560WHT0
Whirlpool KGYE560WPL0
Whirlpool KGYE560WTO0
Whirlpool KGYE560WWH0 Residential Dryer
Whirlpool KGYE650VAL0
Whirlpool KGYE650VHT0
Whirlpool KGYE650VPL0
Whirlpool KGYE650VTO0
Whirlpool KGYE650VWH0 Residential Dryer
Whirlpool KGYE660WAL0 GAS DRYER
Whirlpool KGYE660WAL1
Whirlpool KGYE660WHT0 GAS DRYER
Whirlpool KGYE660WPL0 GAS DRYER
Whirlpool KGYE660WTO0 GAS DRYER
Whirlpool KGYE660WWH0 Residential Dryer
Whirlpool KGYE660WWH1 Residential Dryer
Whirlpool KGYE664WWH0 Residential Dryer
Whirlpool KGYE664WWH1 Residential Dryer
Whirlpool KGYE665BAL0 GAS DRYER
Whirlpool KGYE665BAL1 GAS DRYER
Whirlpool KGYE665BWH0 GAS DRYER
Whirlpool KGYE665BWH1 GAS DRYER
Whirlpool KGYE665BWH3 GAS DRYER
Whirlpool KGYE670BAL0 GAS DRYER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
One gas burner not lighting: No spark djrosen Oven Repair (including Ranges and Cooktops) 5 08-21-2012 05:54 PM
Igniter continues to spark w/ knob in "Off" Steve Y Oven Repair (including Ranges and Cooktops) 0 11-24-2011 06:41 AM
One burner knob won't activate spark. swellwood Oven Repair (including Ranges and Cooktops) 0 05-06-2010 08:09 PM
Confirm Tappan Range Top & Sealed Burner Screw Removal farmer186 Oven Repair (including Ranges and Cooktops) 0 01-24-2010 11:52 AM
Confirm Tappan Range Top & Sealed Burner Screw Removal farmer186 Trash Compactor Repair 0 01-24-2010 11:40 AM
