Discuss
Need Help GE Built in double Oven wont heat
 in
My over is just over a year old. I had the same oven for 20 years with no problems but
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Need Help GE Built in double Oven wont heat
  #1 (permalink)
Old 01-18-2014, 04:04 PM
Junior Member
DeeLynn is on a distinguished road
Default Need Help GE Built in double Oven wont heat
Model Number: JRP28SK1SS   Brand: GE   Age: 1 - 5 years
My over is just over a year old. I had the same oven for 20 years with no problems but when it died I bought the same kind.
It worked fine then all of a sudden it won't heat up. I called GE they came out the guy said it's not getting 220 something is either wrong with the circuit breaker or the wiring. charged me $90.00.
i called out an electrician he checked the circuit breaker Nothing wrong. We pulled the over out of the wall tested the wiring that comes up from the circuit breaker box no problem. He tested the outlet when it plugs into No problem. Another 180.00.
Called back GE they are coming back out Wednesday but they were really insistent it is the electric. It lights up turns on just won't get hot. It should go to 350 when you turn it on but the digital display only shows 100 but it does not heat at all.
I really need some help with this I can't afford to spend more on this. What could be wrong?
Related Models
General Electric JRP28SK1SS Electric range
General Electric JRS04BW1BB Electric range
General Electric JRS04BW2BB Electric range
General Electric JRS04BW3BB Electric range
General Electric JRS04BW4BB Electric range
General Electric JRS04BW5BB Electric range
General Electric JRS04BW6BB Electric range
General Electric JRS04GP1 Electric range
General Electric JRS04GP2BG Electric range
General Electric JRS04GT1BB Electric range
General Electric JRS04GV1BB Electric range
General Electric JRS06BJ1BB Electric range
General Electric JRS06SK1SS Electric range
Jenn-Air JRS1202W REF - SXS
Jenn-Air JRS202 REF - SXS
Jenn-Air JRS202B REF - SXS
Jenn-Air JRS202H REF - SXS
Jenn-Air JRS202L REF - SXS
Jenn-Air JRS202N REF - SXS
Jenn-Air JRS202W REF - SXS
Jenn-Air JRS203 REF - SXS
Jenn-Air JRS203-AQ01B JENN-AIR REFRIGERATION
Jenn-Air JRS203-BQ01A JENN-AIR REFRIGERATION
Jenn-Air JRS203B Ref - Sxs
Jenn-Air JRS205L REF - SXS
Jenn-Air JRS205W REF - SXS
Jenn-Air JRS206A REF - SXS
Jenn-Air JRS206W REF - SXS
Jenn-Air JRS221 REF - SXS
Jenn-Air JRS223 REF - SXS
Jenn-Air JRS223B REF - SXS
Jenn-Air JRS223L REF - SXS
Jenn-Air JRS223N REF - SXS
Jenn-Air JRS223W REF - SXS
Jenn-Air JRS226 REF - SXS
Jenn-Air JRS226B REF - SXS
Jenn-Air JRS226L REF - SXS
Jenn-Air JRS226N REF - SXS
Jenn-Air JRS226W REF - SXS
Jenn-Air JRS227B REF - SXS
Jenn-Air JRS227W REF - SXS
Jenn-Air JRS228B REF - SXS
Jenn-Air JRS228W REF - SXS
Jenn-Air JRS229A REF - SXS
Jenn-Air JRS229B REF - SXS
Jenn-Air JRS229W REF - SXS
Jenn-Air JRSD209A REF - SXS/I&W
Jenn-Air JRSD209B REF - SXS/I&W
Jenn-Air JRSD209TA REF - SXS/I&W
Jenn-Air JRSD209TB REF - SXS/I&W
Jenn-Air JRSD209TW REF - SXS/I&W
Jenn-Air JRSD209W REF - SXS/I&W
Jenn-Air JRSD224 REF - SXS/I&W
Jenn-Air JRSD224B REF - SXS/I&W
Jenn-Air JRSD224L REF - SXS/I&W
Jenn-Air JRSD224N REF - SXS/I&W
Jenn-Air JRSD224W REF - SXS/I&W
Jenn-Air JRSD225 REF - SXS/I&W
Jenn-Air JRSD2250A REF - SXS/I&W
Jenn-Air JRSD2250W REF - SXS/I&W
Jenn-Air JRSD225B Ref - SXS/I&W
Jenn-Air JRSD225L REF - SXS/I&W
Jenn-Air JRSD226 REF - SXS/I&W
Jenn-Air JRSD226B Ref - SXS/I&W
Jenn-Air JRSD227B REF - SXS/I&W
Jenn-Air JRSD227W REF - SXS/I&W
Jenn-Air JRSD229A REF - SXS/I&W
Jenn-Air JRSD229B REF - SXS/I&W
Jenn-Air JRSD229W REF - SXS/I&W
Jenn-Air JRSD245 REF - SXS/I&W
Jenn-Air JRSD2450A REF - SXS/I&W
Jenn-Air JRSD2450W REF - SXS/I&W
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Double Built In Oven dilly2013 Oven Repair (including Ranges and Cooktops) 0 12-18-2013 06:42 PM
Whirlpool Double Built In Oven dilly2013 Oven Repair (including Ranges and Cooktops) 0 12-18-2013 06:41 PM
Built in double oven a-parks@comcast.net Oven Repair (including Ranges and Cooktops) 1 07-05-2012 10:31 AM
1966 Hotpoint electri double oven wont heat up rossb1 Oven Repair (including Ranges and Cooktops) 0 09-05-2009 08:53 AM
Built-in double oven Greg Walls Oven Repair (including Ranges and Cooktops) 1 07-09-2009 12:38 PM
