Discuss
Kitchenaid Double oven error code issue
 in
Issue started with fan not shutting off after several hours. Turned off breaker for 1 minute and got error code
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Kitchenaid Double oven error code issue
  #1 (permalink)
Old 01-17-2014, 11:37 AM
Junior Member
MCS9865 is on a distinguished road
Default Kitchenaid Double oven error code issue
Model Number: KEBC278K SSO   Brand: Kitchen Aid   Age: 5 - 10 years
Issue started with fan not shutting off after several hours. Turned off breaker for 1 minute and got error code F1 F3 EO Per the forum I replaced the upper oven sensor. Oven started for about 5 seconds, stopped and received same error code. Tried power re-set and still get the error code.
I did replace the control board about 5 years ago.
Related Models
Whirlpool KEBC278KBL0 OVEN
Whirlpool KEBC278KBL02 27" Built-In Electric Thermal Convection Double Oven
Whirlpool KEBC278KBL03 27" BUILT-IN ELECTRIC RANGE THERMAL CONVECTION DOUBLE OVEN
Whirlpool KEBC278KBL04 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC278KBL1 DOUBLE OVEN
Whirlpool KEBC278KBS0 OVEN
Whirlpool KEBC278KBS1 DOUBLE OVEN
Whirlpool KEBC278KBT0 OVEN
Whirlpool KEBC278KBT02 27" Built-In Electric Thermal Convection Double Oven
Whirlpool KEBC278KBT03 27" BUILT-IN ELECTRIC RANGE THERMAL CONVECTION DOUBLE OVEN
Whirlpool KEBC278KBT04 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC278KBT1 DOUBLE OVEN
Whirlpool KEBC278KSS0 OVEN
Whirlpool KEBC278KSS02 27" Built-In Electric Thermal Convection Double Oven
Whirlpool KEBC278KSS03 27" BUILT-IN ELECTRIC RANGE THERMAL CONVECTION DOUBLE OVEN
Whirlpool KEBC278KSS04 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC278KSS1 DOUBLE OVEN
Whirlpool KEBC278KWH0 OVEN
Whirlpool KEBC278KWH02 27" Built-In Electric Thermal Convection Double Oven
Whirlpool KEBC278KWH03 27" BUILT-IN ELECTRIC RANGE THERMAL CONVECTION DOUBLE OVEN
Whirlpool KEBC278KWH04 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN
Whirlpool KEBC278KWH1 DOUBLE OVEN
Whirlpool KEBI100BBL0 30" ELEC BUILT-IN OVEN
Whirlpool KEBI100BBL1 ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100BBL2 30" ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100BBL3 30" ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100BWH0 30" ELECTRIC OVEN
Whirlpool KEBI100BWH1 30" ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100BWH2 30" ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100BWH3 30" ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100SBL0 ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100SBL1 ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100TBL1 ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100VBL0 ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100VBL1 ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100VBL2 ELECTRIC RANGE
Whirlpool KEBI100VBL3 ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100WWH0 ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100YBL0 ELEC. BUILT-IN OVEN
Whirlpool KEBI100YBL1 ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100YBL3 30" ELEC BUILT-IN OVEN
Whirlpool KEBI100YWH0 ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100YWH2 ELECTRIC BUILT-IN OVEN
Whirlpool KEBI100YWH3 ELECTRIC BUILT-IN OVEN
Whirlpool KEBI101DBL1 ELECTRIC RANGE
Whirlpool KEBI101DBL10 ELECTRIC OVEN
Whirlpool KEBI101DBL11 BUILT-IN OVEN, ELECTRIC
Whirlpool KEBI101DBL12 BUILT IN OVEN
Whirlpool KEBI101DBL2 BUILT IN OVENS
Whirlpool KEBI101DBL4 BUILT IN OVEN
Whirlpool KEBI101DBL6 OVEN
Whirlpool KEBI101DBL7 OVEN
Whirlpool KEBI101DBL8 ELECTRIC OVEN
Whirlpool KEBI101DBL9 ELECTRIC OVEN
Whirlpool KEBI101DWH1 ELECTRIC RANGE
Whirlpool KEBI101DWH10 ELECTRIC OVEN
Whirlpool KEBI101DWH11 BUILT-IN OVEN, ELECTRIC
Whirlpool KEBI101DWH12 BUILT IN OVEN
Whirlpool KEBI101DWH2 ELECTRIC BUILT IN OVEN
Whirlpool KEBI101DWH4 BUILT IN OVEN
Whirlpool KEBI101DWH6 30" BUILT-IN ELECTRIC OVEN SELF-CLEAN
Whirlpool KEBI101DWH7 OVEN
Whirlpool KEBI101DWH8 ELECTRIC OVEN
Whirlpool KEBI101DWH9 ELECTRIC OVEN
KitchenAid KEBI107DWH10 BUILT-IN ELECTRIC OVEN
Whirlpool KEBI140SBL0 ELECTRIC RANGES & OVENS
Whirlpool KEBI140SBL1 ELECTRIC BUILT-IN OVEN
Whirlpool KEBI141BBL0 24" BUILT-IN ELECTRIC OVEN
Whirlpool KEBI141BBL1 24" BUILT-IN ELECTRIC SELF CLEAN OVEN
Whirlpool KEBI141BBL2 IMPERIAL 24" BUILT-IN ELECTRIC SELF CLEAN OVEN
Whirlpool KEBI141BBL3 24" BUILT-IN ELECTIC OVEN
Whirlpool KEBI141BWH0 24" BUILT-IN ELECTRIC OVEN
Whirlpool KEBI141BWH1 24" BUILT-IN ELECTRIC SELF CLEAN OVEN
Whirlpool KEBI141BWH2 IMPERIAL 24" BUILT-IN ELECTRIC SELF CLEAN OVEN
Whirlpool KEBI141BWH3 24" BUILT-IN ELECTIC OVEN
Whirlpool KEBI141DBL1 Built-In Oven, Electric
Whirlpool KEBI141DBL10 OVEN
Whirlpool KEBI141DBL11 BUILT-IN OVEN, ELECTRIC
Whirlpool KEBI141DBL2 Built-In Oven, Electric
Whirlpool KEBI141DBL4 24" BUILT-IN ELECTRIC SINGLE OVEN
Whirlpool KEBI141DBL6 24" BUILT-IN ELECTRIC SINGLE OVEN SELF-CLEAN
Whirlpool KEBI141DBL7 OVEN
Whirlpool KEBI141DBL8 ELECTRIC OVEN
Whirlpool KEBI141DBL9 OVEN
Whirlpool KEBI141DWH1 Built-In Oven, Electric
Whirlpool KEBI141DWH10 OVEN
Whirlpool KEBI141DWH11 BUILT-IN OVEN, ELECTRIC
Whirlpool KEBI141DWH2 24" BUILT-IN ELECTRIC OVEN
Whirlpool KEBI141DWH4 24" BUILT-IN ELECTRIC SINGLE OVEN
Whirlpool KEBI141DWH6 24" BUILT-IN ELECTRIC SINGLE OVEN SELF-CLEAN
Whirlpool KEBI141DWH7 OVEN
Whirlpool KEBI141DWH8 ELECTRIC OVEN
Whirlpool KEBI141SBL0 Ranges, Electric*
KitchenAid KEBI141SBL1 Ranges, Electric*
Whirlpool KEBI141WBL0 Ranges, Electric*
Whirlpool KEBI141WBL1 Ranges, Electric*
Whirlpool KEBI141WBL2 Ranges, Electric*
Whirlpool KEBI141WBL3 Ranges, Electric*
Whirlpool KEBI141XBL0 Ranges, Electric*
Whirlpool KEBI141XBL1 Ranges, Electric*
Whirlpool KEBI141YBL0
Whirlpool KEBI141YBL1 Ranges, Electric*
Whirlpool KEBI141YBL2 Ranges, Electric*
Whirlpool KEBI141YBL4 24" ELEC BUILT-IN OVEN
Whirlpool KEBI141YWH0 Ranges, Electric*
Whirlpool KEBI141YWH1 Ranges, Electric*
Whirlpool KEBI141YWH3 Ranges, Electric*
Whirlpool KEBI141YWH4 Ranges, Electric*
Whirlpool KEBI170SBL0 ELECTRIC RANGES & OVENS
Whirlpool KEBI170SBL1 ELECTRIC BUILT-IN OVEN
Whirlpool KEBI171BBL0 27" BUILT-IN ELECTRIC OVEN
Whirlpool KEBI171BBL1 27" BUILT-IN ELECTRIC SINGLE SELF CLEAN OVEN
Whirlpool KEBI171BBL2 IMPERIAL 27" BUILT-IN ELECTRIC SINGLE SELF-CLEAN OVEN
Whirlpool KEBI171BBL3 27" BUILT-IN ELECTRIC SINGLE SELF CLEAN OVEN
Whirlpool KEBI171BWH0 27" BUILT-IN ELECTRIC OVEN
Whirlpool KEBI171BWH1 27" BUILT-IN ELECTRIC SINGLE SELF CLEAN OVEN
Whirlpool KEBI171BWH2 IMPERIAL 27" BUILT-IN ELECTRIC SINGLE SELF-CLEAN OVEN
Whirlpool KEBI171DBL1 ELECTRIC RANGE
Whirlpool KEBI171DBL10 BUILT IN OVEN
Whirlpool KEBI171DBL11 BUILT-IN OVEN, ELECTRIC
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kitchenaid Double Oven -- Error Code F2 - E1 -- How to Repair sdbmb Oven Repair (including Ranges and Cooktops) 8 02-17-2012 04:39 PM
Whirlpool double oven error code E1-F5 davandvic Oven Repair (including Ranges and Cooktops) 1 02-09-2011 05:14 AM
E6 F2 error code for Whirlpool double oven ddelay Oven Repair (including Ranges and Cooktops) 4 01-27-2010 06:31 AM
Whirlpool Double Oven w/ error code Quisty Oven Repair (including Ranges and Cooktops) 2 01-26-2009 08:28 AM
Kitchenaid Double Wall Oven Error E1-F2 iraslotnick Oven Repair (including Ranges and Cooktops) 14 12-17-2008 08:49 PM
