We have a Whirlpool Gas range that frequently has PF failures while baking. I have only witnessed it first hand a couple of times and it seems to happen after the ignitor clicks. After doing some Google searches, it looks like the same symptoms covered by this Service Pointer. However, the service pointer states that it is applicable to RK01 through RR07 and my serial number is RS4116998, so I not sure it applies. Would installing the ferrite bead kit help or do I likely have a different issue? Jason
