Used broil in the AM and worked fine. That evening went to use oven and burner started getting hot then went cold. Wife said that she smelled plastic smell for a second. Have not tried any repair or check out yet. Both berners are not getting hot. All controls work at the control panel. Attached micro-wave works ok.
