About two months ago, the fault code F7 showed up on our GE Double Oven. Short-term fix was to turn off the circuit breaker, remove the ribbon connector and clean the contacts with a pencil eraser. Replace and power-up, sometimes it worked, sometimes it didn't. Spoke with a Tech in Customer Service and they recommended a new ERC Control. Ordered it, replaced it, same problem. Have shipped it back since it did not fix the issue.
Oven has worked intermittently ever since. Even this morning, after numerous attempts at powering off, remove and re-insert ribbon connector, oven powers on to read "TEST." Let it sit for 10 minutes, hit the Bake button and yep, she's back to working. Am hopeful this does not require a new Panel Control Assembly(?).
Any assistance will be greatly appreciated. And, as always, will re-post once this is fixed to help anyone else with this similar issue.
