| » Electric Range Oven and Stove do not work |
Model Number: MER6771AAW Brand: Maytag Age: 5 - 10 years
My Maytag Gemini Double Oven with stove has both the Stove Top and Both Ovens that will not come on. Electric is still on as the Clock and other items work (Timer etc.) None of the heating elements will come on. What parts do I need? Thank you.
Related Models |
Here is a service manual
http://www.servicematters.com/maytag...s/16010107.pdf Sounds like you have lost the 240 volts. Have you tried turning the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker. Next check at the plug to see if you have 240 volts. Then at the terminal strip in the unit. Also check here for a wire that may have burned off.
__________________
| Display Modes | |
| Electric Range - Stove Top won't heat | DIY_landlord | Oven Repair (including Ranges and Cooktops) | 0 | 07-25-2009 05:30 PM |
| Whirlpool Electric Stove Doesn't Work Now | RAZDAZ2626 | Oven Repair (including Ranges and Cooktops) | 1 | 05-31-2009 02:49 PM |
| Kenmore gas range igniter does not work on stove cook top | dkaurut01 | Oven Repair (including Ranges and Cooktops) | 0 | 05-14-2009 03:00 PM |
| Electric Range - loud bang - oven doesn't work | lwild | Oven Repair (including Ranges and Cooktops) | 1 | 03-13-2009 02:20 PM |
| bROILER AND STOVE WORK BUT NOT OVEN | aburns24 | Oven Repair (including Ranges and Cooktops) | 2 | 11-20-2008 05:48 PM |
