Discuss
Broiler & Oven turn on at same time
 in
Dear Forum Members, We have a Thermador dual fuel gas stovetop/electric oven. When the oven is set to bake
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Broiler & Oven turn on at same time
  #1 (permalink)
Old 02-12-2008, 05:32 PM
Intandem Intandem is offline
Junior Member
Intandem is on a distinguished road
Default Broiler & Oven turn on at same time
Model Number: Unsure   Brand: Thermador   Age: 5 - 10 years
Dear Forum Members,
We have a Thermador dual fuel gas stovetop/electric oven. When the oven is set to bake the broiler turns on too. I think it may be in the electrical circuit board on the front panel but not sure. Any ideas?
Thank you for your help.
Sincerely,
Intandem
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-29-2008, 08:50 AM
Servicer Servicer is offline
Senior Expert
APP Volunteer
Servicer is on a distinguished road
Default
Hello,
Is the clock on your range digital and in the center of the unit? If so, it sounds like an RDFS, RDDS, etc.. To be sure, you can remove the kick panel to access the data tag. If it is one of these ranges, the unit may cycle between the two elements while baking, but they should not both be glowing red at the same time. If this is the case, the only component which controls the elements is the control board, Thermador part number 486752.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
kenmore oven broiler will not turn off hilgen Oven Repair (including Ranges and Cooktops) 1 01-27-2008 05:37 PM
Unable to turn oven or broiler on momof3 Oven Repair (including Ranges and Cooktops) 1 12-10-2007 04:04 PM
Kenmore oven cooling fan on all the time skh32 Oven Repair (including Ranges and Cooktops) 0 11-13-2007 08:58 AM
Broiler won't turn off!! knobjock Oven Repair (including Ranges and Cooktops) 0 08-14-2007 07:22 PM
oven takes long time to cook Wmurky Oven Repair (including Ranges and Cooktops) 2 07-29-2007 01:01 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
