| » Another KitchenAid Superba stops working after cleaning cycle |
Model Number: KEBS207DBLG Brand: Kitchen Aid Age: 5 - 10 years
This one stopped just a few minutes shy of the end of the 3 1/2 hour cycle, so the door is locked shut. This happened before, years ago and some part was replaced and the oven worked. Another thread with a similar but not exactly the same model showed a need to test with some sensor ? to determine if a thermal fuse needs replacing. I didn't know if this likely applied to mine and if so, how do I track down the part? Plus, how do I get the door to open?
I also have the plastic/rubbery cover for the controls that is partially detached when cool I believe this was a result of the oven heat fromt the cleaning cycle. It looks like it should be able to be "glued" back but I don't know what to use? Last, when cleaning the oven the old fashioned way-with a spray, some of the spray ran in through the oven door and onto the glass and I would like to get that cleaned. If this oven is worth saving is there an easy way to get to the glass to clean it? That's all I have Thanks for any and all help Ads By Google Related Models |
| Display Modes | |
| Cleaning cycle killed our KitchenAid Superba double oven, help? | plnorcal | Oven Repair (including Ranges and Cooktops) | 54 | 04-02-2013 07:47 PM |
| Ice Maker on Kitchenaid Superba Not working - | cdhall99 | Refrigerator & Freezer Repair | 9 | 09-26-2012 10:04 AM |
| Oven not working after self cleaning cycle | jivery | Oven Repair (including Ranges and Cooktops) | 12 | 02-04-2011 05:08 PM |
| KitchenAid Superba all of the sudden, stops delivering ice and water | Jeff_Digs_Kung_Fu | Refrigerator & Freezer Repair | 0 | 10-27-2009 02:50 AM |
| Kitchenaid Superba suddenly stopped working | Jerry69 | Dishwasher Repair | 2 | 03-11-2009 03:51 PM |
