Discuss
Oven light bulb not working
 in
Hi I have a Kenmore gas range. The oven light bulb burnt out the other day. I replaced the bulb
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven light bulb not working
  #1 (permalink)
Old 12-13-2013, 12:00 PM
Junior Member
custom_bill is on a distinguished road
Default Oven light bulb not working
Model Number: 79072904011   Brand: Kenmore   Age: 1 - 5 years
Hi I have a Kenmore gas range. The oven light bulb burnt out the other day. I replaced the bulb and it still doesn't work. I tested the bulb in a lamp socket and it works.
So I pulled the back panel off the stove and found the socket and the two wires attached to it. I pulled the wires off, plugged in the stove, shut the oven door, and pushed the light button on the control panel on, and put a tester on the wires and no electric going to the socket.
This test bypassed the oven door switch. Does anyone know whats wrong?
Related Models
Kenmore 79072904011 GAS RANGE
Kenmore 79072904012 GAS RANGE
Kenmore 79072909010 GAS RANGE
Kenmore 79072909011 GAS RANGE
Kenmore 79072909012 GAS RANGE
Kenmore 79073052400 GAS RANGE
Kenmore 79073052401 GAS RANGE
Kenmore 79073052402 GAS RANGE
Kenmore 79073052404 GAS RANGE
Kenmore 79073052405 GAS RANGE
Kenmore 79073053400 GAS RANGE
Kenmore 79073053401 GAS RANGE
Kenmore 79073053402 GAS RANGE
Kenmore 79073053403 GAS RANGE
Kenmore 79073053404 GAS RANGE
Kenmore 79073053405 GAS RANGE
Kenmore 79073054400 GAS RANGE
Kenmore 79073054401 GAS RANGE
Kenmore 79073054402 GAS RANGE
Kenmore 79073054404 GAS RANGE
Kenmore 79073054405 GAS RANGE
Kenmore 79074042300 GAS RANGE
Kenmore 79074044300 GAS RANGE
Kenmore 7907432190 GAS RANGE
Kenmore 7907432890 GAS RANGE
Kenmore 79074403990 DUAL FUEL RANGE
Kenmore 79074403991 DUAL FUEL RANGE
Kenmore 79074403992 DUAL FUEL RANGE
Kenmore 79074403993 DUAL FUEL RANGE
Kenmore 79074403994 DUAL FUEL RANGE
Kenmore 79074403995 DUAL FUEL RANGE
Kenmore 79074503990 DUAL FUEL RANGE
Kenmore 79074503991 DUAL FUEL RANGE
Kenmore 79074503992 DUEL FUEL RANGE
Kenmore 7907482190 GAS RANGE
Kenmore 7907482890 GAS RANGE
Kenmore 7907492990 GAS RANGE
Kenmore 79075193300 GAS RANGE
Kenmore 79075193301 GAS RANGE
Kenmore 79075193302 GAS RANGE
Kenmore 79075403500 GAS RANGE
Kenmore 79075403501 GAS RANGE
Kenmore 79075413300 GAS RANGE
Kenmore 79075413301 GAS RANGE
Kenmore 79075413302 GAS RANGE
Kenmore 79075503200 RANGE
Kenmore 79075503201 RANGE
Kenmore 79075503202 RANGE
Kenmore 79075503203 RANGE
Kenmore 79075503204 RANGE
Kenmore 79075503206 RANGE
Kenmore 79075503207 RANGE
Kenmore 79075503208 RANGE
Kenmore 79075602100 GAS RANGE
Kenmore 79075602102 GAS RANGE
Kenmore 79075602104 GAS RANGE
Kenmore 79075602105 GAS RANGE
Kenmore 79075602106 GAS RANGE
Kenmore 79075603700 GAS RANGE
Kenmore 79075603701 GAS RANGE
Kenmore 79075603702 GAS RANGE
Kenmore 79075604100 GAS RANGE
Kenmore 79075604102 GAS RANGE
Kenmore 79075604104 GAS RANGE
Kenmore 79075604105 GAS RANGE
Kenmore 79075604106 GAS RANGE
Kenmore 79075609100 GAS RANGE
Kenmore 79075609102 GAS RANGE
Kenmore 79075609104 GAS RANGE
Kenmore 79075609105 GAS RANGE
Kenmore 79075609106 GAS RANGE
Kenmore 79075651000 GAS RANGE
Kenmore 79075651001 GAS RANGE
Kenmore 79075651002 GAS RANGE
Kenmore 79075652000 GAS RANGE
Kenmore 79075652001 GAS RANGE
Kenmore 79075652002 GAS RANGE
Kenmore 79075657000 GAS RANGE
Kenmore 79075657001 GAS RANGE
Kenmore 79075657002 GAS RANGE
Kenmore 79075658000 GAS RANGE
Kenmore 79075658001 GAS RANGE
Kenmore 79075658002 GAS RANGE
Kenmore 79075660100 GAS RANGE
Kenmore 79075660101 GAS RANGE
Kenmore 79075660103 GAS RANGE
Kenmore 79075660104 GAS RANGE
Kenmore 79075661100 GAS RANGE
Kenmore 79075661101 GAS RANGE
Kenmore 79075661103 GAS RANGE
Kenmore 79075661104 GAS RANGE
Kenmore 79075662100 GAS RANGE
Kenmore 79075662101 GAS RANGE
Kenmore 79075662102 GAS RANGE
Kenmore 79075662103 GAS RANGE
Kenmore 79075662104 GAS RANGE
Kenmore 79075663200 GAS RANGE
Kenmore 79075663201 GAS RANGE
Kenmore 79075663202 GAS RANGE
Kenmore 79075664100 GAS RANGE
Kenmore 79075664101 GAS RANGE
Kenmore 79075664102 GAS RANGE
Kenmore 79075664103 GAS RANGE
Kenmore 79075664104 GAS RANGE
Kenmore 79075711890 ELECTRIC RANGE
Kenmore 79075711891 GAS RANGE
Kenmore 79075711892 GAS RANGE
Kenmore 79075711893 GAS RANGE
Kenmore 79075715890 Free Standing, Electric
Kenmore 79075715891 GAS RANGE
Kenmore 79075715893 GAS RANGE
Kenmore 79075716890 GAS RANGE
Kenmore 79075716891 GAS RANGE
Kenmore 79075716893 GAS RANGE
Kenmore 79075718890 ELECTRIC RANGE
Kenmore 79075718891 GAS RANGE
Kenmore 79075718892 GAS RANGE
Kenmore 79075718893 GAS RANGE
Kenmore 79075721990 GAS RANGE
Kenmore 79075721991 GAS RANGE
  #2 (permalink)
Old 12-14-2013, 02:50 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Here is a wiring diagram.
http://manuals.frigidaire.com/prodin.../316519825.pdf
Unplug the unit.
Check at the control board using resistance to be sure the door switch closes when the door is closed.
Install the light bulb and check at the control board to Neutral to see if you measure the light bulb resistance.
If both the above are OK then I would say that the problem is in the control board.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Refrigerator Light Not Working, Bulb not burned out lysemag Refrigerator & Freezer Repair 1 03-15-2012 01:49 PM
How to replace light bulb inside micro. can't find bulb location mcolleran Microwave Repair 0 07-30-2011 07:44 PM
fridge light not working bulb not burned out tburk Refrigerator & Freezer Repair 0 06-12-2011 07:21 AM
hoodvent fan and light out after touching broken off light bulb with new bulb threads dtseckinger Microwave Repair 1 04-27-2009 07:21 PM
oven light bulb assembly gretchenfl Oven Repair (including Ranges and Cooktops) 1 11-21-2008 04:56 PM
