Getting F2, F3, and F% error codes. Have replaced the temp sensor, but it didn't affect the problem. Now have a replacement control board, but it's different than the existing. Main issue are the leads for Bake & Broil. The existing control board has a single tab connector for each that is independent of the . . . well . . black boxes. The replacement has 2 connection options for Bake and 3 for Broil, all w/in the black boxes.
Do I have the correct part, and if so, where to I connect the Bake and Broil leads?
Thanks . .
DC
