Discuss
oven will not heat up
 in
My oven will not heat up. The broiler is working fine. I am thinking the ignition switch may need to
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » oven will not heat up
  #1 (permalink)
Old 10-15-2009, 12:56 PM
tmurch tmurch is offline
Junior Member
tmurch is on a distinguished road
Default oven will not heat up
Model Number: AGR5835QDS   Brand: Amana   Age: 5 - 10 years
My oven will not heat up. The broiler is working fine. I am thinking the ignition switch may need to be changed. Any ideas?
Related Models
Amana AGR5835QDS Range - S/c F/s Gas
Amana AGR5835QDW Range - S/c F/s Gas
General Electric AGS05LAG1 Room air conditioner
General Electric AGS05LHG1 Room air conditioner
General Electric AGS05LJG1 Room air conditioner
General Electric AGS08AAG1 Room air conditioner
Amana AGS1740BDQ Range - S/c S/i Gas
Amana AGS1740BDW Range - S/c S/i Gas
Amana AGS3760BDB Range - S/c S/i Gas
Amana AGS3760BDQ Range - S/c S/i Gas
Amana AGS3760BDS Range - S/c S/i Gas
Amana AGS3760BDW Range - S/c S/i Gas
Amana AGS5730BDB Range - S/c S/i Gas
Amana AGS5730BDQ Range - S/c S/i Gas
Amana AGS5730BDS Range - S/c S/i Gas
Amana AGS5730BDW Range - S/c S/i Gas
Amana AGS720 Range - F/s Std Gas
Amana AGS730L Range - S/c S/i Ddraft Gas
Amana AGS730W Range - S/c S/i Ddraft Gas
Amana AGS740 Range - F/s Std Gas
Amana AGS741L Range - S/c S/i Ddraft Gas
Amana AGS741W Range - S/c S/i Ddraft Gas
Amana AGS743L Range - S/c S/i Ddraft Gas
Amana AGS743W Range - S/c S/i Ddraft Gas
Amana AGS745E Range - S/c S/i Ddraft Gas
Amana AGS745E1 Range - S/c S/i Ddraft Gas
Amana AGS745W Range - S/c S/i Ddraft Gas
Amana AGS745WW Range - S/c S/i Ddraft Gas
Amana AGS745WW1 Range - S/c S/i Ddraft Gas
Amana AGS746E Range - S/c S/i Gas
Amana AGS746WW Range - S/c S/i Gas
Amana AGS750L Range - S/c S/i Ddraft Gas
Amana AGS750W Range - S/c S/i Ddraft Gas
Amana AGS751L Range - S/c S/i Ddraft Gas
Amana AGS751L1 Range - S/c S/i Ddraft Gas
Amana AGS751W Range - S/c S/i Ddraft Gas
Amana AGS751W1 Range - S/c S/i Ddraft Gas
Amana AGS760L Range - S/c S/i Ddraft Gas
Amana AGS760W Range - S/c S/i Ddraft Gas
Amana AGS760WW Range - S/c S/i Ddraft Gas
Amana AGS761L Range - S/c S/i Ddraft Gas
Amana AGS761L1 Range - S/c S/i Ddraft Gas
Amana AGS761LL Range - S/c S/i Ddraft Gas
Amana AGS761W Range - S/c S/i Ddraft Gas
Amana AGS761W1 Range - S/c S/i Ddraft Gas
Amana AGS761WW Range - S/c S/i Ddraft Gas
Amana AGS780E Range - S/c S/i Ddraft Gas
Amana AGS780WW Range - S/c S/i Ddraft Gas
Amana AGS781E Range - S/c S/i Ddraft Gas
Amana AGS781LL Range - S/c S/i Ddraft Gas
Amana AGS781WW Range - S/c S/i Ddraft Gas
General Electric AGT05LBG1 Room air conditioner
General Electric AGT05LHG1 Room air conditioner
Frigidaire AGTL175WH1-57 Tap(v7) / Top Mount Refrigerator
Frigidaire AGTN175WH1-57 Tap(v2) / Top Mount Refrigerator
General Electric AGV05LBG1 Room air conditioner
General Electric AGV05LCG1 Room air conditioner
General Electric AGV05LHG1 Room air conditioner
General Electric AGV05LJG1 Room air conditioner
General Electric AGV06LHG1 Room air conditioner
General Electric AGV06LJG1 Room air conditioner
General Electric AGV07LAG1 Room air conditioner
General Electric AGV07LBG1 Room air conditioner
General Electric AGV08AAG1 Room air conditioner
General Electric AGV08AHG1 Room air conditioner
General Electric AGV08AJG1 Room air conditioner
General Electric AGV08FAM1 Room air conditioner
General Electric AGV08FBM1 Room air conditioner
General Electric AGV10AAG1 Room air conditioner
General Electric AGV10ABG1 Room air conditioner
General Electric AGV10ACG1 Room air conditioner
General Electric AGV10ADG1 Room air conditioner
General Electric AGV10AHG1 Room air conditioner
General Electric AGV10AJG1 Room air conditioner
General Electric AGV12AAG1 Room air conditioner
General Electric AGV12AAG2 Room air conditioner
General Electric AGV12ABG1 Room air conditioner
General Electric AGV12ACG1 Room air conditioner
General Electric AGV12ADG1 Room air conditioner
General Electric AGV12AHG1 Room air conditioner
General Electric AGV12AJG1 Room air conditioner
General Electric AGV12DAG1 Room air conditioner
General Electric AGV12DBG1 Room air conditioner
General Electric AGV12DCG1 Room air conditioner
General Electric AGV14AAG1 Room air conditioner
General Electric AGV14AHG1 Room air conditioner
General Electric AGV14AJG1 Room air conditioner
  #2 (permalink)
Old 10-15-2009, 03:32 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Check if there is 120 VAC to the Bake igniter (#14 on the diagram) while the control calls for Bake.
If there is proper voltage then the igniter is the culprit.
- The oven igniter Part number: AP4096256
Here are the breakdown diagrams and Replacement parts for AMANA AGR5835QDS | AppliancePartsPros.com
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
oven lock light is on and oven will not heat jimfunke Oven Repair (including Ranges and Cooktops) 0 04-20-2009 10:06 AM
oven lock light is on and oven will not heat jimfunke Oven Repair (including Ranges and Cooktops) 0 04-20-2009 10:02 AM
Caloric double oven/bottom oven doesn't heat kj0505 Oven Repair (including Ranges and Cooktops) 1 12-10-2008 10:14 AM
oven lighter comes on but oven doesn't heat dack Oven Repair (including Ranges and Cooktops) 1 10-27-2008 04:31 PM
Bosch 27" Dbl oven Powering on but no heat either oven badace Oven Repair (including Ranges and Cooktops) 0 12-02-2007 10:56 AM
