Discuss
Thermador Range top removal questions
 in
I am replacing the oven/control electronic panel and am having a problem removing the range top: I have all
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Thermador Range top removal questions
  #1 (permalink)
Old 10-15-2009, 09:47 AM
din209@bellsouth.net din209@bellsouth.net is offline
Junior Member
din209@bellsouth.net is on a distinguished road
Default Thermador Range top removal questions
Model Number: RDDS30V   Brand: Thermador   Age: 5 - 10 years
I have all the venturi's removed EXCEPT for the left rear. As I unscrew the venturi, something underneath is also twisting as I turn the socket. Additionally, this particular venturi is extremely difficult to unscrew. Any suggestions? The top must come off to replace the control panel!
Thanks (also, should I put some graphite or other "lube" on the venturi's when I re-assemble?
Thanks again.
Related Models
Thermador RDDS30V
Thermador RDDS30VQB PRIOR TO S/N 9707
Thermador RDDS30VQB S/N 9707 & UP
Thermador RDDS30VRS PRIOR TO S/N 9707
Thermador RDDS30VRS S/N 9707 & UP
Whirlpool RDE1100W0
Whirlpool RDE1100W1
Whirlpool RDE1100W2
Whirlpool RDE1300W
Whirlpool RDE1300W1
Whirlpool RDE1300W2
Whirlpool RDE1400W
Whirlpool RDE1400W1
Whirlpool RDE1400W2
Whirlpool RDE22302
Whirlpool RDE2300W
Whirlpool RDE2300W1
Whirlpool RDE2300W2
Whirlpool RDE2400P0
Whirlpool RDE2400P1
Whirlpool RDE2400P2
Whirlpool RDE2400W0
Whirlpool RDE2400W1
Whirlpool RDE2400W2
Whirlpool RDE2500P0
Whirlpool RDE2500P1
Whirlpool RDE2500P2
Whirlpool RDE3000W
Whirlpool RDE3020W
Whirlpool RDE3100W
Whirlpool RDE31E0W
Whirlpool RDE32302
Whirlpool RDE3230W
Whirlpool RDE3300W
Whirlpool RDE3340W
Whirlpool RDE3360W
Whirlpool RDE3400W
Whirlpool RDE3400W1
Whirlpool RDE3400W2
Whirlpool RDE3450W
Whirlpool RDE34EPW
Whirlpool RDE350PW
Whirlpool RDE350PW1
Whirlpool RDE355PP
Whirlpool RDE3600W
Whirlpool RDE3600W2
Whirlpool RDE3700W
Whirlpool RDE3700W1
Whirlpool RDE3700W2
Whirlpool RDE3900W
Whirlpool RDE3900W1
Whirlpool RDE390PW
Whirlpool RDE390PW2
Whirlpool RDE3950W
Whirlpool RDE395PP
Whirlpool RDE4400W0
Whirlpool RDE4400W1
Whirlpool RDE4400W2
Whirlpool RDE4900W
Whirlpool RDE4900W1
Whirlpool RDE4900W2
Whirlpool RDE4950W
Whirlpool RDE6030W0
Whirlpool RDE6030W1
Whirlpool RDE6030W2
Whirlpool RDE6030W3
Whirlpool RDE6100W
Whirlpool RDE6100W1
Whirlpool RDE6100W2
Whirlpool RDE6300W
Whirlpool RDE6300W1
Whirlpool RDE6300W2
Whirlpool RDE630PN0
Whirlpool RDE6550W
Whirlpool RDE6550W1
Whirlpool RDE6550W2
Whirlpool RDE6700W
Whirlpool RDE6700W1
Whirlpool RDE6700W2
Whirlpool RDE8400W
Whirlpool RDE8400W1
Whirlpool RDE8400W2
Whirlpool RDE8500W
Whirlpool RDE8500W1
Whirlpool RDE8500W2
Whirlpool RDE8550
Whirlpool RDE85501
Whirlpool RDE85502
Whirlpool RDE950PW
Whirlpool RDE950PW1
Whirlpool RDE950PW2
Whirlpool RDE955PP
Whirlpool RDE9600W
Whirlpool RDE9600W2
Thermador RDF30
Thermador RDF30QB PRIOR TO S/N 9708
Thermador RDF30QB S/N 9708 & UP
Thermador RDF30QW PRIOR TO S/N 9708
Thermador RDF30QW S/N 9708 & UP
Thermador RDF30RS PRIOR TO S/N 9707
Thermador RDF30RS S/N 9707 & UP
Thermador RDFS30
Thermador RDFS30 PRIOR TO S/N 9708
Thermador RDFS30 S/N 9708 & UP
Whirlpool RDH2030
Whirlpool RDH2036
Whirlpool RDH2330
Whirlpool RDH2336
Whirlpool RDH2630
Whirlpool RDH2636
Whirlpool RDH4330
Whirlpool RDH4336
Whirlpool RDH4630
Whirlpool RDH4636
Whirlpool RDH7330
Whirlpool RDH7336
Whirlpool RDH7630
Whirlpool RDH7636
Whirlpool RDH8330
Whirlpool RDH8630
  #2 (permalink)
Old 10-15-2009, 08:00 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Default
The venturi goes into the jet holder (Jet holder assembly replacement parts for THERMADOR RDDS30V | AppliancePartsPros.com) which is connected to the aluminum gas tube from the gas burner valve.
Looks like whatever was twisted is most likely this jet holder, and the gas tube is already broken. I'm afraid you have to cut this burner and venturi just to remove them and the top panel. Then you have to replace what ever got damaged. Looks like parts for this model are still available.
Here are the the breakdown diagrams and Replacement parts for THERMADOR RDDS30V | AppliancePartsPros.com
__________________
  #3 (permalink)
Old 10-16-2009, 05:58 AM
Junior Member
Default
Gene, Thank you for your reply. Damn. Any ideas on how to 'cut' out the burner / venturi? I had the thought of removing panels to get access under the top, but upon review saw that the burner box will not allow entry from the side. What should have been a 20 minute job has turned quite ugly!
  #4 (permalink)
Old 10-16-2009, 03:47 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You probably can use a small cutting tool, like a Dremel. The worst thing is you have to finish this job anyway due to a possible gas leak.
__________________
  #5 (permalink)
Old 11-03-2009, 02:22 PM
greghj greghj is offline
Junior Member
greghj is on a distinguished road
Default
Quote:
Same thing just happened to me... a simple job to replace the control panel has turned into a nightmare. I snapped off two of the jet holders while trying to remove the top and damaged the gas tube as well. As suggested, I was able to get the top off by cutting the venturi tube (a hack saw and 30 minutes does the job, with only minor damage to the cook top).
So, here's the rub. For the RDDS30 prior to 9707, the gas tube assemblies are no longer available. In 1997 they started using a different valve with a different sized fitting in a different location: the replacement simply doesn't fit. I'm not sure what to do here... I'd hate have to buy a new range simply because I can't find a couple of aluminum tubes. Any hints?
  #6 (permalink)
Old 11-03-2009, 04:32 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The best and, probably the only, solution is:
Buy an aluminum tube the same diameter as original. Cut off all compression nuts from the old tubes. Cut the new tubes as needed to fit properly and bend them exactly as the old one are. Find any refrigerator repair store in your area and ask them to make a flare connections for the new tubes, using the old nuts.
In order to cut the tubes you will need a mini tube cutter Part number: AP3550533
__________________
  #7 (permalink)
Old 11-03-2009, 09:09 PM
Junior Member
Default
Gene,
Thanks for the info. I have ordered all the parts and all but the tube have arrived. I have a post 97 stove - but will now check the parts I have to make sure they all fit as I hope they will ... and will call back in to see when the backordered (and paid for) tubing will arrive to complete the job. UGH! A simple repair with the control panel went into a tail spin! ... Good suggestion on the tubing fix. Thanks again.
  #8 (permalink)
Old 11-04-2009, 12:47 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thermador gas cooktop - deep questions grapedog Oven Repair (including Ranges and Cooktops) 1 10-10-2009 08:44 PM
Thermador wall oven removal arnold12 Oven Repair (including Ranges and Cooktops) 0 07-05-2009 03:17 PM
thermador range top rogerdrake Oven Repair (including Ranges and Cooktops) 3 03-15-2009 07:24 AM
Range Top Removal? JASON GRAY Oven Repair (including Ranges and Cooktops) 0 01-26-2008 03:12 PM
Tappan gas range top removal plehan Oven Repair (including Ranges and Cooktops) 0 12-15-2007 03:21 PM
