STOVE TOP burner problem. There is gas leaking under the rim of the burner head that will ignite when the burner lights. Need to order the correct part and replace. Not sure what part to request. Also, another burner has ignition problems and I would like to get the right part for this. Is part number AP4394705(whirpool) correct one which is the sealed burner assembly I should order? The specifications page of Maytag indicates Sealed Surface Burners for this model. Also, any pointers on removal of the burners? I have had Appliance NINJA helped me in past questions. Thank you. randall729.
