| » Error Code PF / Oven not working |
Model Number: GW395LEPS03 Brand: Whirlpool Age: 1 - 5 years
The oven portion on my Whirlpool stove is not working and has a code of PF, which I am assuming means power failure. The range works fine. I paid a technician 60.00 to diagnose the electronic control piece. I ordered it from APP and installed, however that did not fix the problem. Does anyone have any suggestions? Is it maybe the control panel? I hate to just throw expensive parts at it...Does anyone have the wiring diagram?
According to the manufacturer Service pointer, the correction is to install the ferrite bead kit to reduce line interference (electrical noise) from the direct spark ignition module.
You also may want to make sure there is nothing wrong with the wall outlet and the circuit breaker for the range. Would not heart to install a power surge protector for the range (even better for a whole house). - The ferrite bead kit (comes with the installation instructions) Part number: AP3593684 Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GW395LEPS03 | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Quote:
I hope you can clarify them for me/ everyone. Is the ferrite bead intended to cover BOTH the wire harness (leaving the spark module from one side of the board) AND the 6 spark wires (leaving the spark module from the other side, on their way to ignitors). Or is it just intended to cover the wire harness without covering the 6 spark wires? Thanks in advance' D. |
This instructions made by Whirlpool. Sometimes their instructions are not very clear or even mistaken but not this one.
It is specifically written in the installation instructions (steps 5 & 6): "main wire harness" and "going to the spark module". On the other side it says nothing about any wires "leaving the spark module". Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com Last edited by Gene : 08-23-2010 at 07:38 PM. |
Thanks, Gene - I really appreciate your expert advice!
I think I speak for the rest of my fellow amateurs here on the forum when I say that you've been a great help. I feel guilty about not having to at least buy you a beer or something! You've done enough, so don't feel compelled to answer this follow-up question, but do you think it would be a bad idea to put an extra ferrite bead over the 6 'spark wires' that extend from the other side of the 'spark module' to the igniters? As I understand it, electrical noise/ interference from the spark module is causing problems in the very nearby (and expensive to replace) 'oven control board'. If covering the 'wire harness' extending from one side of the spark module with a ferrite bead helps to shield the delicate oven control board, why wouldn't another ferrite bead over the 6 spark wires also be needed to fully shield the control board? Is it because the 6 spark wires already have a ferrite coating running along their length? Or is it because a ferrite bead over the spark wires would inhibit them to the point where they couldn't spark the igniters? Thanks, again, Gene! And I'm not kidding. I owe you a beer! |
Thank you for your good words!
I believe Whirlpool engineers did deep investigation regarding this problem before they offered this solution. I do not think that more ferrite bead should be used. If your range is made after March of 2004, then that possible electrical noise more likely was already fixed. Gene.
__________________
| Display Modes | |
| F1 error code GE oven | Duane Hari | Oven Repair (including Ranges and Cooktops) | 0 | 12-12-2009 10:45 PM |
| Oven Error Code F3 | dbboyer | Oven Repair (including Ranges and Cooktops) | 0 | 04-18-2009 11:10 AM |
| 1 oven gives error code E-6 | domfixit | Oven Repair (including Ranges and Cooktops) | 0 | 03-19-2009 08:01 AM |
| oven error code | ilbcnu52 | Oven Repair (including Ranges and Cooktops) | 1 | 11-14-2008 03:53 PM |
| Oven error code | Squillo | Oven Repair (including Ranges and Cooktops) | 0 | 12-05-2007 09:43 AM |
