2 Pages12>
massimo33162
#1 Posted : Friday, November 22, 2013 6:59:58 AM(UTC)
massimo33162
just bought new igniter and it still does not work -no clicking sound- strangely when you put the igniter on for the next burner -this igniter starts clicking -so in order to light this burner yu have to light the burner next to it -so i would say the igniter does work but indirectly ...in other words if you want to light this broken burner - (since the gas comes out but no clicking sound ) yu need to light another burner first -i know its not the end of the world but i did buy a new igniter it would be nice if this worked on its own like it was supposed to
Appliance Ninja
#2 Posted : Friday, November 22, 2013 7:12:04 AM(UTC)
Appliance Ninja
The issue is likely with the switch on the valve shaft, not the igniter. Each valve has a small switch that, when the valve is turned on, energizes the spark module so the igniters will spark. I suspect that switch is faulty. May I please have your model number so I am able to provide you with accurate, model specific information?
massimo33162
#3 Posted : Friday, November 22, 2013 7:19:18 AM(UTC)
massimo33162
frigidaire(electrolux)- PLCS389ACC --THANK YU -I BET THE IGNITER DID NOT EVEN HAVE TO BE REPLACED
Appliance Ninja
#4 Posted : Friday, November 22, 2013 7:26:51 AM(UTC)
Appliance Ninja
Thank you! Number 3 in the picture below is the igniter switch. I have posted a link to that part below. I agree that the original igniter was probably okay.
Frigidaire 316032002 Switch, Ign - AppliancePartsPros.com
Appliance Ninja attached the following image(s):
massimo33162
#5 Posted : Friday, November 22, 2013 7:28:23 AM(UTC)
massimo33162
massimo33162
#6 Posted : Friday, November 22, 2013 7:41:04 AM(UTC)
massimo33162
Could Yu Send Me Any Directions Putting It In -is It Hard To Put In? Assuming I Have To Take The Whole Range Top Off As Well ..thank Yu Again
Appliance Ninja
#7 Posted : Friday, November 22, 2013 7:41:11 AM(UTC)
Appliance Ninja
Your information is above....
massimo33162
#8 Posted : Friday, November 22, 2013 7:45:50 AM(UTC)
massimo33162
Ok Thank Yu
Appliance Ninja
#9 Posted : Friday, November 22, 2013 7:47:27 AM(UTC)
Appliance Ninja
You are very welcome, have a great weekend!
massimo33162
#10 Posted : Friday, November 22, 2013 9:14:12 AM(UTC)
massimo33162
one more thing the warmer draw on this unit does not close properly- just bought a new rail from you and that was not the problem -it might be (has to be) the female rails -cant for the life of me understand why the draw does not closse all the way -mid way the draw jams -are those bering glides supposed to move or be stationary ? hard to see because you cant see what is jamming the slide warmer door
Oven Buttons not working and igniter problem (Oven Repair (including Ranges and Cooktops))
by Paul Briant 4/14/2013 11:31:39 AM(UTC)
Do I have an igniter problem? (Oven Repair (including Ranges and Cooktops))
by ginbeach 9/5/2012 1:45:46 PM(UTC)
Dryer Igniter Problem? (Dryer Repair)
by Danielwolfmountain 1/23/2012 1:52:16 PM(UTC)
Thermador PGR304ZS igniter problem (Oven Repair (including Ranges and Cooktops))
by mtangney 11/24/2010 10:10:59 AM(UTC)
GE Range igniter problem (Oven Repair (including Ranges and Cooktops))
by chuckcarlino 9/15/2010 9:58:25 AM(UTC)
GE Stove/Range, range Igniter problem (Refrigerator & Freezer Repair)
by chuckcarlino 9/15/2010 3:34:22 AM(UTC)
Magic Chef top igniter problem (Oven Repair (including Ranges and Cooktops))
by techsan47 9/13/2010 11:04:58 AM(UTC)
igniter problem? (Heating, Ventilation, and Air Conditioning (HVAC))
by ski1of5 3/19/2010 10:42:39 AM(UTC)
Igniter Problems (Oven Repair (including Ranges and Cooktops))
by dp1313 12/23/2009 2:02:01 PM(UTC)
More igniter problems (Oven Repair (including Ranges and Cooktops))
by dp1313 12/5/2009 2:24:23 PM(UTC)
Bosch Cooktop Igniter Problem (Oven Repair (including Ranges and Cooktops))
by ddoughty56 7/26/2009 10:50:24 AM(UTC)
GE JGP933 Faulty Igniter Problem (Oven Repair (including Ranges and Cooktops))
by Scott Lawson 1/5/2009 4:29:14 PM(UTC)
GE Cooktop Igniter problems (Oven Repair (including Ranges and Cooktops))
by KatyTx 12/27/2008 7:27:46 PM(UTC)
GE Profile Igniter Problem (Oven Repair (including Ranges and Cooktops))
by tim a 8/29/2008 10:53:41 PM(UTC)
2 Pages12>
