Discuss
Oven won't heat- bake or broil
 in
I'll try to be as detailed as possible: Breaker in the garage wired to oven tripped while preheating. Upon further
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven won't heat- bake or broil
  #1 (permalink)
Old 10-13-2009, 09:09 PM
Junior Member
STARKYPDX is on a distinguished road
Default Oven won't heat- bake or broil
Model Number: FEF357BBB   Brand: Frigidaire   Age: 1 - 5 years
Upon further inspection in garage it appears the main house breaker went down at same time.
No other breakers tripped. only oven and main.
Reset breakers main house and oven
Cook top works fine. convection fan working, oven light working, no fault codes.
Oven not working. Bake or Broil elements will not heat.
Trouble shot as follows:
Swapped breakers in garage- no change. oven still not working.
Checked power at wall socket in kitchen. I have 120v on both legs
Checked power at the dist block on back of range. Have 120v on both legs
Unplug bake element and broil element wires and removed both elements.
When oven set to bake: no heating
I have 120v at the "blue wire" and 120v at the yellow wire.
Orange wire that connects to both is dead.
When oven set to broil:
When oven set to off:
I have 0 at blue and 0 at yellow wire.
orange wire that connect to both is dead.
Question:
Elements both go out somehow? any way to check them?
Should I have 240v on the yellow/blue wires or is 120v ok?
What have I missed any thoughts?
Related Models
Frigidaire FEF357BBB Frigidaire/electric Range
Frigidaire FEF357BBC Frigidaire/electric Range
Frigidaire FEF357BBD Frigidaire/electric Range
Frigidaire FEF357BBE Frigidaire/electric Range
Frigidaire FEF357BEDA Frg(v1) / Electric Range
Frigidaire FEF357BEDB Frg(v1) / Electric Range
Frigidaire FEF357BEDC Frg(v1) / Electric Range
Frigidaire FEF357BEDD Frg(v1) / Electric Range
Frigidaire FEF357BEDE Frg(v1) / Electric Range
Frigidaire FEF357BEWA Frg(v2) / Electric Range
Frigidaire FEF357BEWB Frg(v2) / Electric Range
Frigidaire FEF357BEWC Frg(v2) / Electric Range
Frigidaire FEF357BEWD Frg(v2) / Electric Range
Frigidaire FEF357BEWE Frg(v2) / Electric Range
Frigidaire FEF357BGWA Frg(v0) / Electric Range
Frigidaire FEF357BSA Frigidaire/electric Range
Frigidaire FEF357BSB Frigidaire/electric Range
Frigidaire FEF357BSC Frigidaire/electric Range
Frigidaire FEF357BSD Frigidaire/electric Range
Frigidaire FEF357BSE Frigidaire/electric Range
Frigidaire FEF357BSF Frigidaire/electric Range
Frigidaire FEF357CESA Frg(v3) / Electric Range
Frigidaire FEF357CESB Frg(v3) / Electric Range
Frigidaire FEF357CESC Frg(v0) / Electric Range
Frigidaire FEF357CESD Frg(v3) / Electric Range
Frigidaire FEF357CESE Frg(v3) / Electric Range
Frigidaire FEF357CGBA Frg/electric Range
Frigidaire FEF357CGSA Frg/electric Range
Frigidaire FEF358BFDA Frg(v1) / Electric Range
Frigidaire FEF358BFDB
Frigidaire FEF358BFDC
Frigidaire FEF358BFDD Frg(v1) / Electric Range
Frigidaire FEF358BFWA Frg(v2) / Electric Range
Frigidaire FEF358BFWB
Frigidaire FEF358BFWC
Frigidaire FEF358BFWD Frg(v2) / Electric Range
Frigidaire FEF358CFSA Frg(v3) / Electric Range
Frigidaire FEF358CFSB
Frigidaire FEF358CFSC
Frigidaire FEF358CFSD Frg(v0) / Electric Range
Frigidaire FEF361AWA Frigidaire/range
Frigidaire FEF361AWB Frigidaire/electric Range
Frigidaire FEF361AWD Frigidaire/electric Range
Frigidaire FEF361AWE Frigidaire/electric Range
Frigidaire FEF361AWF Frigidaire/electric Range
Frigidaire FEF361AWG Frigidaire/electric Range
Frigidaire FEF362BXAWA Frigidaire/electric Range
Frigidaire FEF362BXAWB Frigidaire/electric Range
Frigidaire FEF362BXAWC Frigidaire/electric Range
Frigidaire FEF362BXAWD Frigidaire/electric Range
Frigidaire FEF362MXAWA Frigidaire/electric Range
Frigidaire FEF362MXESA Frigidaire/electric Range
Frigidaire FEF362MXESB Frigidaire/range
Frigidaire FEF362MXESC Frigidaire/electric Range
Frigidaire FEF362MXESD Frigidaire/range
Frigidaire FEF363BXAWA Frigidaire/electric Range
Frigidaire FEF363BXAWB Frigidaire/electric Range
Frigidaire FEF363SGWA Frg(v1) / Range
Frigidaire FEF363SGWB Frg(v2) / Range
Frigidaire FEF364BXAWA Frigidaire/electric Range
Frigidaire FEF364DQA Frigidaire/electric Range
Frigidaire FEF364DQB Frigidaire/electric Range
Frigidaire FEF364DSA Frigidaire/electric Range
Frigidaire FEF364DSB Frigidaire/electric Range
Frigidaire FEF364DSD Frigidaire/range
Frigidaire FEF364DSE Frigidaire/range
Frigidaire FEF364DUA Frigidaire/electric Range
Frigidaire FEF364DUB Frigidaire/electric Range
Frigidaire FEF364DWA Frigidaire/electric Range
Frigidaire FEF364DWB Frigidaire/electric Range
Frigidaire FEF364DWD Frigidaire/range
Frigidaire FEF364DWE Frigidaire/range
Frigidaire FEF364FSA Frigidaire/range
Frigidaire FEF364FSB Frigidaire/electric Range
Frigidaire FEF364FSC Frigidaire/range
Frigidaire FEF364FWA Frigidaire/range
Frigidaire FEF364FWB Frigidaire/electric Range
Frigidaire FEF364FWC Frigidaire/range
Frigidaire FEF364SADA Frg(v1) / Electric Range
Frigidaire FEF364SAWA Frg(v2) / Electric Range
Frigidaire FEF365AQA Frigidaire/electric Range
Frigidaire FEF365AQB Frigidaire/electric Range
Frigidaire FEF365AQC Frigidaire/electric Range
Frigidaire FEF365AQD Frigidaire/electric Range
Frigidaire FEF365AQE Frigidaire/electric Range
Frigidaire FEF365AQF Frigidaire/electric Range
Frigidaire FEF365ASA Frigidaire/range
Frigidaire FEF365ASB Frigidaire/range
Frigidaire FEF365ASC Frigidaire/range
Frigidaire FEF365ASD Frigidaire/electric Range
Frigidaire FEF365ASE Frigidaire/electric Range
Frigidaire FEF365ASF Frigidaire/electric Range
Frigidaire FEF365ASG Frigidaire/electric Range
Frigidaire FEF365ASH Frigidaire/electric Range
Frigidaire FEF365ASJ Frigidaire/electric Range
Frigidaire FEF365ASK Frigidaire/electric Range
Frigidaire FEF365ASL Frigidaire/electric Range
Frigidaire FEF365BGDA Frg(v1) / Electric Range
Frigidaire FEF365BGDB Frg(v1) / Electric Range
Frigidaire FEF365BGDC Frg(v1) / Electric Range
Frigidaire FEF365BGDD ELECTRIC RANGE
Frigidaire FEF365BGDE Frigidaire/electric Range
Frigidaire FEF365BGWA Frg(v2) / Electric Range
Frigidaire FEF365BGWB Frg(v2) / Electric Range
Frigidaire FEF365BGWC Frg(v2) / Electric Range
Frigidaire FEF365BGWD ELECTRIC RANGE
Frigidaire FEF365BGWE Frigidaire/electric Range
Frigidaire FEF365BUA Frigidaire/electric Range
Frigidaire FEF365BUB Frigidaire/electric Range
Frigidaire FEF365BUC Frigidaire/electric Range
Frigidaire FEF365BUD Frigidaire/electric Range
Frigidaire FEF365BUE Frigidaire/electric Range
Frigidaire FEF365BUF Frigidaire/electric Range
Frigidaire FEF365BUG Frigidaire/electric Range
Frigidaire FEF365BUH Frigidaire/electric Range
Frigidaire FEF365BWA Frigidaire/electric Range
Frigidaire FEF365BWB Frigidaire/electric Range
Frigidaire FEF365BWC Frigidaire/electric Range
Frigidaire FEF365BWD Frigidaire/electric Range
Frigidaire FEF365BWE Frigidaire/electric Range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
top electric wall oven won't heat (bake or broil) kenoven Oven Repair (including Ranges and Cooktops) 0 12-30-2009 07:33 AM
oven won't heat up bake or broil Paulz916 Oven Repair (including Ranges and Cooktops) 1 11-19-2009 03:50 AM
Oven Heat On Broil But Not Bake jamepc Oven Repair (including Ranges and Cooktops) 0 05-04-2009 04:30 PM
oven will not heat on bake but broil and stove top works fine picksadoodle Oven Repair (including Ranges and Cooktops) 1 01-10-2009 08:26 PM
Oven wont heat on bake or broil brad27 Oven Repair (including Ranges and Cooktops) 4 01-23-2008 06:25 PM
