Discuss
Oven flame modulation
 in
This is a Hardwick gas 20" apartment range with pilots. Operates on natural gas. I suspect this stove is from
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven flame modulation
  #1 (permalink)
Old 11-21-2013, 07:08 AM
Junior Member
woodman46 is on a distinguished road
Default Oven flame modulation
Model Number: ?????   Brand: Hardwick   Age: More than 10 years
This is a Hardwick gas 20" apartment range with pilots. Operates on natural gas. I suspect this stove is from the 1950's. The oven heats to temperature but gas flame shuts off completely when it reaches temp rather than modulating down. When heat is called for it ignites "full on again" then shuts completely down again at temperature.
We recently moved. Stove worked OK in former location. Upon lighting the burner pilot in new house I noticed the pilot flame was over 1 inch high. Adjusted pilot down to normal level. Oven pilot is OK and extends to sensing rod when oven is turned on.
I'm suspecting higher pressure gas in this new location. Did not use a pressure regulator in former house but I have used one in the past on another old gas range. Could my oven control problem be due to higher gas pressure at new location? If so, what "in line" regulator should I purchase?
Related Models
General Electric A*B588D Room air conditioner
General Electric A*B588E Room air conditioner
General Electric A*B688D Room air conditioner
General Electric A*B688E Room air conditioner
Frigidaire A04LE2E1 Frg(v1) / Room Air Conditioner
Frigidaire A04LE2F1 Frg(v1) / Room Air Conditioner
Frigidaire A05LE2E1 Frg(v2) / Room Air Conditioner
Frigidaire A05LE2E2 Frg(v4) / Room Air Conditioner
Frigidaire A05LE2E3 Frg(v1) / Room Air Conditioner
Frigidaire A05LE2E7 Frg(v1) / Room Air Conditioner
Frigidaire A05LE2N1 Frg(v1) / Room Air Conditioner
Frigidaire A05LH5E1 Frg(v1) / Room Air Conditioner
Frigidaire A05LH5F1 Frg(v1) / Room Air Conditioner
Frigidaire A05LH5F2 Frg(v1) / Room Air Conditioner
Frigidaire A05LH5K1 Frg(v1) / Room Air Conditioner
Frigidaire A05LH5L1 Frg(v1) / Room Air Conditioner
Frigidaire A05LH5N1 Frg(v0) / Room Air Conditioner
Frigidaire A05LH8F1 Frg(v1) / Room Air Conditioner
Frigidaire A05LH8L1 Frg(v1) / Room Air Conditioner
Frigidaire A05LH8N1 Frg(v1) / Room Air Conditioner
Frigidaire A05LS1F1 Frg(v1) / Air Conditioner
Frigidaire A05LS1N1 Frg(v1) / Room Air Conditioner
Frigidaire A06LE2E1 Frg(v3) / Room Air Conditioner
Frigidaire A06LE2E2 Frg(v1) / Room Air Conditioner
Frigidaire A06LE2E3 Frg(v2) / Room Air Conditioner
Frigidaire A06LE2K1 Frg(v1) / Room Air Conditioner
Frigidaire A06LE2L1 Frg(v1) / Room Air Conditioner
Frigidaire A06LE2N1 Frg(v1) / Room Air Conditioner
Frigidaire A06LE3E1 Frg(v1) / Room Air Conditioner
Frigidaire A06LH5E1 Frg(v1) / Room Air Conditioner
Frigidaire A06LH5E2 Frg(v1) / Room Air Conditioner
Frigidaire A06LH5F1 Frg(v1) / Room Air Conditioner
Frigidaire A06LH5L1 Frg(v1) / Room Air Conditioner
Frigidaire A06LH5N1 Frg(v1) / Room Air Conditioner
Frigidaire A06LH6F1 Frg(v1) / Room Air Conditioner
Frigidaire A06LH6L1 Frg(v1) / Room Air Conditioner
Frigidaire A06LH8E1 Frg(v1) / Room Air Conditioner
Frigidaire A07LH8E1 Frg(v1) / Room Air Conditioner
Frigidaire A07LH8E2 Frg(v1) / Room Air Conditioner
Frigidaire A07LH8E3 Frg(v1) / Room Air Conditioner
Frigidaire A07LH8L1 Frg(v1) / Room Air Conditioner
Frigidaire A08LE2E1 Frg(v1) / Room Air Conditioner
Frigidaire A08LE2E2 Frg(v2) / Room Air Conditioner
Frigidaire A08LE2N1 Frg(v1) / Room Air Conditioner
Frigidaire A08LE2N2 Frg(v1) / Room Air Conditioner
Frigidaire A08LH5E1 Frg(v1) / Room Air Conditioner
Frigidaire A08LH5E2 Frg(v2) / Room Air Conditioner
Frigidaire A08LH5F1 Frg(v1) / Room Air Conditioner
Frigidaire A08LH5L1 Frg(v1) / Room Air Conditioner
Frigidaire A08LH5L2 Frg(v1) / Room Air Conditioner
Frigidaire A08LH5L3 Frg(v1) / Room Air Conditioner
Frigidaire A08LH8N1 Frg(v1) / Room Air Conditioner
Frigidaire A08ME2E1 Frg(v1) / Room Air Conditioner
Frigidaire A08ME2E2 Frg(v2) / Room Air Conditioner
Frigidaire A08ME2E3 Frg(v1) / Room Air Conditioner
Frigidaire A08ME2E4 Frg(v1) / Room Air Conditioner
Whirlpool A0W23W10 Air-conditioner/heat pump
Jenn-Air A100 ELE CARTRIDGE
Jenn-Air A100-8 ELE CARTRIDGE
Jenn-Air A100-C ELE CARTRIDGE
Jenn-Air A100B ELE CARTRIDGE
Jenn-Air A100B-8 ELE CARTRIDGE
Jenn-Air A100B-C ELE CARTRIDGE
Jenn-Air A100L ELE CARTRIDGE
Jenn-Air A100L-C ELE CARTRIDGE
Maytag A100S WASHER-TOP LOADING
Jenn-Air A100S-8 ELE CARTRIDGE
Jenn-Air A100W ELE CARTRIDGE
Jenn-Air A100W-8 ELE CARTRIDGE
Jenn-Air A100W-C ELE CARTRIDGE
Maytag A101 WASHER-TOP LOADING
Maytag A102 WASHER-TOP LOADING
Maytag A102S WASHER-TOP LOADING
Maytag A103 WASHER-TOP LOADING
Maytag A103S WASHER-TOP LOADING
Maytag A104 WASHER-TOP LOADING
Maytag A105 WASHER-TOP LOADING
Jenn-Air A105-8 MISC / ACCESSORY
Jenn-Air A105W-8 MISC / ACCESSORY
Maytag A106 WASHER-TOP LOADING
Jenn-Air A106B ELE CARTRIDGE
Maytag A106S WASHER-TOP LOADING
Jenn-Air A106W ELE CARTRIDGE
Maytag A107 WASHER-TOP LOADING
Maytag A107S WASHER-TOP LOADING
Maytag A108 WASHER-TOP LOADING
Hoover A1089
Maytag A108S WASHER-TOP LOADING
Maytag A110 WASHER-TOP LOADING
Jenn-Air A110-8 MISC / ACCESSORY
Admiral A1100PRA RANGE- F/S STD GAS
Admiral A1100PRA-K RANGE- F/S STD GAS
Admiral A1100PRW RANGE- F/S STD GAS
Admiral A1100PRW-K RANGE- F/S STD GAS
Jenn-Air A111 MISC / ACCESSORY
Jenn-Air A111-8 MISC / ACCESSORY
Maytag A112 WASHER-TOP LOADING
Frigidaire A11ME5E1 Frg(v1) / Room Air Conditioner
Frigidaire A11ME5F1 Frg(v1) / Room Air Conditioner
Frigidaire A11ME5L2 Frg(v1) / Room Air Conditioner
Frigidaire A11ME8E1 Frg(v1) / Room Air Conditioner
Frigidaire A11ME8E2 Frg(v2) / Room Air Conditioner
Frigidaire A11ME8E3 Frg(v1) / Room Air Conditioner
Frigidaire A11MEDC2 Frg(v1) / Room Air Conditioner
Frigidaire A11MEDSD3 Frg(v1) / Room Air Conditioner
Frigidaire A11MEDTC2 Frg(v2) / Room Air Conditioner
Frigidaire A11MEUC2 Frg(v3) / Room Air Conditioner
Frigidaire A11MEUSD2 Frg(v2) / Room Air Conditioner
Frigidaire A11MEUTSD2 Frg(v3) / Room Air Conditioner
Jenn-Air A120 MISC / ACCESSORY
Jenn-Air A120-8 MISC / ACCESSORY
Amana A1200S COMMERCIAL MICROWAVES
Jenn-Air A121B ELE CARTRIDGE
Jenn-Air A121B-8 ELE CARTRIDGE
Jenn-Air A121W ELE CARTRIDGE
Jenn-Air A121W-8 ELE CARTRIDGE
Amana A1225S COMMERCIAL MICROWAVES
Jenn-Air A122B ELE CARTRIDGE
Maytag A122B14 RADIANT ELEMENT CARTRIDGE
Jenn-Air A122W ELE CARTRIDGE
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven does not have enough flame nanilu Oven Repair (including Ranges and Cooktops) 0 11-19-2011 02:12 PM
flame stays lit for a few (20) seconds then goes out. could it be the flame sensor? h grubxx96 Dryer Repair 1 11-11-2011 02:23 PM
Oven flame gillthetrucker Oven Repair (including Ranges and Cooktops) 0 11-15-2010 10:24 AM
Gas flame comes on one time, then no flame just ignitor cycling kwilson263 Dryer Repair 0 07-15-2010 05:36 PM
gas oven, flame goes out after being lit rotten Oven Repair (including Ranges and Cooktops) 4 01-25-2008 05:11 PM
