randall729
#1 Posted : Thursday, November 14, 2013 1:30:54 PM(UTC)
randall729
Burners work fine. Broiler works fine. Oven doesn't light because no gas.
I tap on the oven regulator and oven gets gas. Can hear it and it works.
Your opinion please anyone. Shut off oven and have to repeat the same procedure to get it to work.
Appliance Ninja
#2 Posted : Thursday, November 14, 2013 1:36:29 PM(UTC)
Appliance Ninja
You have a weak bake igniter, a very common problem. The igniter needs to draw at least 3.0 amps through the gas valve for it to work as designed. If the igniter gets weak and does not draw that current, it may not open, only open partially or take a very long time to open. You can verify its failure by measuring the current draw with a clamp on ammeter. The correct igniter for your model is available below.
Whirlpool 12400035 Flat Style Oven Igniter Kit - AppliancePartsPros.com
Thermador prg304us oven burner ignitor does not have power (Oven Repair (including Ranges and Cooktops))
by Corino 1/8/2019 3:21:11 PM(UTC)
Oven burner only ignites correctly the first time (Oven Repair (including Ranges and Cooktops))
by Jmurphy644 3/13/2018 6:00:45 PM(UTC)
Oven burner won't heat anymore (Oven Repair (including Ranges and Cooktops))
by Dechy 12/28/2017 9:11:01 AM(UTC)
Oven burner cycling on and off (Oven Repair (including Ranges and Cooktops))
by Dastardly Dick Dalrymple 9/28/2016 5:05:24 PM(UTC)
oven burner tube flame adjust (Oven Repair (including Ranges and Cooktops))
by randall729 11/15/2013 8:59:35 AM(UTC)
Replaced Oven Burner - Still Don't Work (Oven Repair (including Ranges and Cooktops))
by pauliejr2 9/29/2013 8:25:34 PM(UTC)
GE oven burner valve leaking...which part does it need? (Oven Repair (including Ranges and Cooktops))
by aprilsbrit 2/13/2013 2:11:30 PM(UTC)
Viking Oven Burners Ignite then Shut Off - Please Help - $100 reward! (Oven Repair (including Ranges and Cooktops))
by sepulchral 12/3/2012 9:53:14 AM(UTC)
Whirlpool Gas Oven burner won't ignite (Oven Repair (including Ranges and Cooktops))
by dmargosh 12/1/2012 8:09:54 AM(UTC)
LP oven burner adjustment (Oven Repair (including Ranges and Cooktops))
by roody2 11/16/2012 2:56:29 PM(UTC)
Fridgidaire Oven Burner Shuts Off (Oven Repair (including Ranges and Cooktops))
by DIY Repairer 8/7/2012 12:15:07 PM(UTC)
oven burner flame does not light (Oven Repair (including Ranges and Cooktops))
by angelocerrone 5/22/2012 1:08:21 PM(UTC)
oven burners not lighting (Oven Repair (including Ranges and Cooktops))
by lilmaria 12/16/2011 1:03:43 PM(UTC)
Oven burner does not stay lit (Oven Repair (including Ranges and Cooktops))
by larryo58 7/23/2011 12:16:39 PM(UTC)
Oven Burners stopped working (Oven Repair (including Ranges and Cooktops))
by browns2 6/15/2011 2:17:59 PM(UTC)
