Discuss
Double Wall Oven will not heat up
 in
I have verified that the part number I gave you is correct for your model number. You received part number
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Double Wall Oven will not heat up
  #21 (permalink)
Old 11-20-2013, 02:56 PM
Senior Member
Appliance Ninja is on a distinguished road
Default
I have verified that the part number I gave you is correct for your model number. You received part number WB27T10282, correct? It is not uncommon for there to be extra, unused connections because those controls may fit many different models with features yours may not have.
  #22 (permalink)
Old 11-20-2013, 03:06 PM
Junior Member
jwmingus is on a distinguished road
Default
Yes that is the number I received. will try
  #23 (permalink)
Old 11-20-2013, 03:10 PM
Senior Member
Default
Great, let me know how it goes!
  #24 (permalink)
Old 11-20-2013, 03:34 PM
Junior Member
Default
Have one quick issue. Black marked as C on old board, no such place on new board.
  #25 (permalink)
Old 11-20-2013, 03:43 PM
Senior Member
Default
There should have been a wiring instruction sheet with the control showing where that goes, depending on the style of control you have. Did you get a look at them?
  #26 (permalink)
Old 11-20-2013, 04:00 PM
Junior Member
Default
My bad, I bought elsewhere and no Sheet. I have the Original tech sheet. The difference is the OPEN connection on the new board is marked COM1, on the old board this wire came from C
The wire label is B-12
  #27 (permalink)
Old 11-20-2013, 04:06 PM
Senior Member
Default
That sheet is available below.
CLICK HERE
  #28 (permalink)
Old 11-20-2013, 04:23 PM
Junior Member
Default
Awesome - Shown on E - and F note the connection C is no longer on the new panel..
  #29 (permalink)
Old 11-20-2013, 04:31 PM
Junior Member
Default
C connected on Far Right here on old board. New board label of Com1 open ?
  #30 (permalink)
Old 11-20-2013, 04:36 PM
Senior Member
Default
The black should go to COM1 in that diagram. Do you have blacks to all those connections as shown in figure E?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE profile 30" double wall oven won't heat Kromero5 Oven Repair (including Ranges and Cooktops) 0 11-19-2011 02:38 PM
Ge Double wall oven no heat and pungent smell sloka Microwave Repair 0 02-20-2011 05:27 AM
Ge Double wall oven no heat and pungent smell sloka Refrigerator & Freezer Repair 0 02-20-2011 05:16 AM
Ge Double wall oven sloka Refrigerator & Freezer Repair 3 02-19-2011 08:16 PM
Whirlpool Double Wall Oven Won't Heat... DaveinMD Oven Repair (including Ranges and Cooktops) 2 12-02-2009 07:45 AM
