Discuss
Double Wall Oven will not heat up
 in
They will be single wires on the relays marked with a yellow dot. Those wires run down to the bake
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Double Wall Oven will not heat up
  #11 (permalink)
Old 11-14-2013, 05:02 PM
Senior Member
Appliance Ninja is on a distinguished road
Default
They will be single wires on the relays marked with a yellow dot. Those wires run down to the bake elements.
  #12 (permalink)
Old 11-14-2013, 05:21 PM
Junior Member
jwmingus is on a distinguished road
Default
I have the two yellow shown here. Going into the panel back
I will pull both. Tape off Wire end. Then apply power to the oven.
Turn on oven, then test connection at panel ?
  #13 (permalink)
Old 11-14-2013, 05:26 PM
Senior Member
Default
Correct, turn each oven to bake and measure power at the now empty terminals and see if they read 120 VAC from the terminals to ground.
  #14 (permalink)
Old 11-14-2013, 05:30 PM
Junior Member
Default
please point me to ground. dont wanna die tonight
  #15 (permalink)
Old 11-14-2013, 05:36 PM
Senior Member
Default
Any metal surface on the oven is ground. Sorry I did not clarify that.
  #16 (permalink)
Old 11-14-2013, 05:42 PM
Junior Member
Default
Done - 0 on each test. Some Clicking of Relays.
  #17 (permalink)
Old 11-14-2013, 05:54 PM
Senior Member
Default
Excellent, very well done! That confirms the oven control is faulty. The correct one for your oven is available at the link below.
GE WB27T10282 Electronic Oven Control - AppliancePartsPros.com
  #18 (permalink)
Old 11-14-2013, 05:57 PM
Junior Member
Default
Thanks for the Help. I guess cheaper than a whole new unit.
I really appreciate the guidance.
  #19 (permalink)
Old 11-14-2013, 06:06 PM
Senior Member
Default
You are very welcome, you did a great job! Let me know if you run into trouble during installation of that control.
  #20 (permalink)
Old 11-20-2013, 02:50 PM
Junior Member
Default
Hi Ninja, Received the new control unit. But - More connections on this one than the old one... Are we sure this is a one for one newer part?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE profile 30" double wall oven won't heat Kromero5 Oven Repair (including Ranges and Cooktops) 0 11-19-2011 02:38 PM
Ge Double wall oven no heat and pungent smell sloka Microwave Repair 0 02-20-2011 05:27 AM
Ge Double wall oven no heat and pungent smell sloka Refrigerator & Freezer Repair 0 02-20-2011 05:16 AM
Ge Double wall oven sloka Refrigerator & Freezer Repair 3 02-19-2011 08:16 PM
Whirlpool Double Wall Oven Won't Heat... DaveinMD Oven Repair (including Ranges and Cooktops) 2 12-02-2009 07:45 AM
